Suspension experiment
Started by Beachbum957, June 9, 2026, 12:00
Beachbum957
A number of people have suggested cutting 1/2 coil off the OEM front springs as an alternative to lowering springs and coilovers. We have run different lowering springs on another MR2 and while we liked the handling, ground clearance was a problem.  We have a FL car (2003) that had OEM springs and some spare PFL springs, so we tried the change.
Like others, removing 1/2 coil off the front lowered about 10mm. We first tried 3/4 of a coil, but the spring would not stay in the lower mount, so 1/2 seems about the practical limit.
Doing some spring rate calculations, we concluded this increased the spring rate about 11%.  Most calculations ignore how the springs are mounted and don't compensate for the end treatments as the top coil is inactive as it sits almost fully on the seat, and part of the lower coil is inactive because of the curved lower mount.
As that worked nicely, we decided to try the same in the rear.  That is when we learned the OEM FL rear spring had 1/2 more coils that the PFL and was about 8% softer.  We had PFL rear springs, so we tried cutting 1/2 coil, which would be the same as cutting a full coil off the FL. Again, 1/2 coil off the PFL was about the limit and still stay on the lower mount, so cutting 1 coil off the FL probably would not work.  This lowered the rear about 10mm, but the spring rate was now over 20% stiffer than the FL rear.
Since the rear springs were now stiffer relative to the front than the OEM 2003 FL springs, we removed the rear bar.  We have Koni inserts and had increase damping slightly.
The end result was a car about 10 mm lower front and rear, less roll in the corners, very slightly stiffer ride and very predictable handling with a bit of understeer at the limit.   A relatively simple, effective modification.
I did the 1/2 coil at the front (PFL) and left the rears as is.
Also very happy with the feel and handling.  Mind you, I am running 16" at the rear in order to have a  better choice for rear tyre.
Beachbum957
We are running 16" front and rear, and tire selection in the US is terrible in 16".  The wheels are 16x7, tires are 195/45-16 F and 205/45-16 R
