Rear foglights not working
Started by Ozzy, July 10, 2026, 14:02
Ozzy
Hi,
Picked up a 2006 MR2 but has a few niggles that need sorting, mainly rear foglights not working which is a biggy for MOT.
Both sides are not working and when turning them on, there's no light on the speedo either. Doubt it matters but front foglights are missing and have no fuse.
I've checked bulbs and a couple other fuses related and all fine.
Anyone got any ideas? Thanks.
mr9
Was about to create a new thread for my problem and thought I'd be a good forum member and see if there are any threads I can answer first.
Undfortunately I don't have an answer but a related problem -  I now have some issues with my foglights which flicker even when not turned on.
This has got progressively worse over time. In the summer I took out the rear bulbs to avoid the danger for drivers behind - and have replaced the left hand indicator stalk to see if it was a switch problem.
This isn't it - so maybe a dodgy ground or relay.
EDIT: I've had a look through a copy of a wiring diagram I have but hte copy is a USA one - so while it has side lights on it it doesn't appear to have rear fog lights. Anyone got a UK wiring diagram?
Given the dash light comes on without activating the switch - and the dash light flickers at the same time as the lights - I would say your problem lies with not being able to activate a relay or on the other side of the relay.
Mine must be on the switch side of the relay. Does anyone know where teh relay is? Is it a relay?  I'll try and find the wiring diagram
mr9
Looks like the relay is on the fusebox behind passenger door.
There are two light blue relays (on my 2006 with front fogs and AC)
The left relay appears t be for the rear fogs (and front?)
You could try swapping them to see if that solves your issue then order a new one.
Part number is 90987-02027.
