P420
Started by Newbie57, August 7, 2026, 20:48
Newbie57
Took some reading off the MAF
Air flow at idle 2.2 to 3 g/s
At 2.5k revs unloaded 8.3 g/s
Newbie57
More investigation tonight.
B2s1 shows consistent high reading a 4k revs. Not cycling as before
Long term fuel trim 10%
Short term at idle -2.7% & -4,3% at idle
Max min voltage on b1s1 b1s2 show fail on diagnostics
That looks ok, based on my vague memories.
But...just going back through the thread..I noticed something..
Would you be able to post your short and long term fuel trims for the 3k-4k range?
Quote from: Newbie57 on August 25, 2026, 20:13More investigation tonight.
Is that 10% positive ? Or negative
Basically I'm starting to suspect injector or something upstream and the cat is just struggling to fight the overfueling.
If it's constantly trimming fuel...then there's your answer. It IS rich. But why...?
Probably injector
Newbie57
Quote from: shnazzle on August 25, 2026, 20:37Is that 10% positive ? Or negative
Probably injector
10% is positive
Quote from: Newbie57 on August 25, 2026, 21:1710% is positive
Damn.
That's that theory out the window.
Hmm...
Ok next theory. Air leak near throttle body.
Unmetered air causing lean condition, so it's dumping in more fuel.
Why is the trim negative at idle you ask? Well, at idle, vacuum is highest, and what you can see is that that vacuum sucks the leak shut. Now because your overall trim is positive, it has to trim fuel down at idle when the leak is shut.
So... Same test as before with the exhaust, spray EGR cleaner or MAF cleaner by the throttle body and the joins by the intake
I have little to contribute to these threads but love reading them. The ROC collective working to solve a problem they are miles away from.
I mentioned intake as an aside earlier on......I think in my mind I was believing it had already been done.....  ???
Pull  the sprk plugs nd see if one is obviously running rich.  If one is, that isolates the issue to an injector.
Quote from: Carolyn on August 26, 2026, 08:05Pull  the sprk plugs nd see if one is obviously running rich.  If one is, that isolates the issue to an injector.
Which the OP already did earlier...all sparks looked fine.
So I guess back to Gaz:s intake leak
Newbie57
Quote from: shnazzle on August 25, 2026, 21:25Damn.
Hmm...
From memory I think short term at 4k revs was +14%
@ Newbie57
Did you fix it?
Newbie57
Quote from: Gaz mr-s on September 20, 2026, 12:16Newbie57
Did you fix it?
putting some miles on ok so far. We will see. Thanks for all the help.
Quote from: Newbie57 on October  4, 2026, 22:13putting some miles on ok so far. We will see. Thanks for all the help.
What was the fix. ?
Newbie57
Not sure it's actually fixed.
I tightened the 3 amigos.
The airbox had popped open. Sothat was put back together.
Done 100 miles or so with no pending codes
