P420
Started by Newbie57, August 7, 2026, 20:48
Newbie57
Fitted a new cat and toyosport manifold at the end of last season. Cleaned the MAF and put in a new air filter. A few miles(200 ish) now issues. Just recently couple of backfires. P420 shows up.
I have changed the plugs. Old ones were a nice grey. Doesn't suggest running rich.
Took it round my local garage. To test immersion. @2k revs all ok. @4k revs looks like overfueling. My sense of smell is non existent but the garage owner said the exhaust smelt a little of petrol fumes.
I could put extenders on the upstream O2 sensors.
Any other suggestions?
Exhaust leaks? Crush and donut gasket gas tight?
Oem or toyo gasket at manifold?
Newbie57
Quote from: Ardent on August  7, 2026, 21:11Exhaust leaks? Crush and donut gasket gas tight?
Manifold gasket OE style steel ditched the toyo one.
Did you use OEM crush rings between the manifiold and cat?
Did you use any exhaust sealing paste?
Is it the original cat?
I suspect the cat is the problem...
Newbie57
Quote from: Carolyn on August  8, 2026, 08:32Did you use OEM crush rings between the manifiold and cat?yes
Did you use any exhaust sealing paste? Rhys did it so I would think so
Is it the original cat? CAT2u
I suspect the cat is the problem...did the  emissions check at the garage co2 is ok
If no leaks, I'd suspect the maf.
Exhaust paste reaslly shouldn't be used upstream of the cat.  But, as it passed emissions, Iit's not the cat.
I'm with Gaz on the MAF as a possibility.  Maf problems don't throw a 'MAF code' but manifest in other codes.
Hawko
From what I understand it's not uncommon for after market cats to throw P420.  I fitted a new one and although passing emissions for the MOT I still get one every now and again, as I believe others have reported.
I occasionally get a smell of petrol fumes on start up and have been through just about everything and wonder that's just a fact that these cars are over fuelled on cold start.
A problem shared is a blame halved
Newbie57
If there is a leak I would expect it to be at the manifold to block interface so the upstream sensors would see too much O2 and add more fuel.
3 amigos would not effect fueling I believe.
Nope, the cat joint would do so.  The manifold with a steel gasket very rarely gives problems.
Do I recall if you give a squib of egr or electrical contact cleaner around the manifold joint, if the revs pick up, you have a leak.
Quote from: Ardent on August  8, 2026, 20:14Do I recall if you give a squib of egr or electrical contact cleaner around the manifold joint, if the revs pick up, you have a leak.
No......the intake.
Trying to think what car i tried this on.
Newbie57
Took this from bank 1 sensor 2. First part of graph is with a 3k rpm. Second part at idle.
This is just at idle.
Looks wrong.
I'm not expert when it comes to sensor traces, but I do know that the post cat barely moves in comparison the manifold ones vary much more.
I'd think your fuel trims would be more useful.  @Carolyn @shnazzle
Agreed.
Was that open loop or closed loop?
Newbie57
Quote from: Gaz mr-s on August 10, 2026, 20:10I'm not expert when it comes to sensor traces, but I do know that the post cat barely moves in comparison the manifold ones vary much more.
Trace is from the manifold O2 not the post cat one.
Quote from: Newbie57 on August 10, 2026, 20:35Trace is from the manifold O2 not the post cat one.
Bank 1 sensor2 is post-cat.  Manifold r/h is 1/1,  l/hand Bank 2/1
Newbie57
Quote from: Gaz mr-s on August 10, 2026, 21:04Bank 1 sensor2 is post-cat.  Manifold r/h is 1/1,  l/hand Bank 2/1
Thanks.
So, cat looks ok at idle but can't handle anything more
Quote from: Newbie57 on August 10, 2026, 22:14Thanks.
Wait until either of the others I notified state what they think is best way forward.
Just jotting down a few potentially helpful notes;
- car is in closed loop at (warm!) idle. So you'll see sensor activity at idle
- car is in open loop at higher loads (narrowband O2 sensors aren't fast/precise enough at those engine speeds)
- post-cat sensor is only there for micro-adjustments for ULEV compliance. Mr-s doesn't even have a post-cat. As per what Gaz said; it should barely move on trace.
- if manifold sensors say all is ok (sensors, not trims) but post-cat does not then you have a leak in the exhaust post-manifold. Jason's (Ardent) test using a spray would alter oxygen levels so if you spray that near the exhaust joints (my bet is crush gaskets).
I'll revisit tomorrow after sleep
Quote from: shnazzle on August 11, 2026, 00:14Jason's (Ardent) test using a spray would alter oxygen levels so if you spray that near the exhaust joints (my bet is crush gaskets).
He can't feel any leak. Is a combustible spray not just for the intake?
Quote from: Gaz mr-s on August 11, 2026, 07:43He can't feel any leak. Is a combustible spray not just for the intake?
Leaks can be tiny and o2 sensors are sensitive. It doesn't have to be combustible. Basically anything that dilutes (or enhances) oxygen in the air. Nitrogen works too :) If you have that handy.
Basically anything "the kids" huff to get high (as it depletes oxygen to the brain) will work.
I had the same issue once. The cause was me being rough with mounting the cat to the mani and one of the crush gaskets shifting slightly and one "corner" becoming flattened and letting in oxygen from the open air
Newbie57
Quote from: shnazzle on August 11, 2026, 08:09Leaks can be tiny and o2 sensors are sensitive. It doesn't have to be combustible. Basically anything that dilutes (or enhances) oxygen in the air. Nitrogen works too :) If you have that handy.
How about brake cleaner or MAF cleaner?
