Need help with radio
Started by jacksonmj43535, August 19, 2026, 16:49
jacksonmj43535
My stock radio (Sony) just randomly turned off yesterday, it had the time on the screen and then I went to play music n it turned off hasn't worked since, was working fine previously
As with many things electrical, unless they are emitting smoke signals (indicating termination), I would check what circuit the radio is on, is anything else on the, same circuit? is that working? if yes then there is a problem with the radio. If not check/ replace that circuit fuse.
SurreyMR2
Under the PTY button there is a reset button. Try resetting it with a paperclip or similar.
