O2 sensor wiring
Started by MR-S Turbo, August 23, 2005, 16:16
MR-S Turbo
I have got a A/F ratio gauge and need to know which O2 sensor to connect it to and also the wiring diagrams for them on a J Spec car.
TRD 2000GT - 500BHP ish
If your taking the signal from the ECU then tap into the wire going to E4 pin12.
JSpec has the same wiring as all the other models.
MR-S Turbo
Is that the 0.05v to 1v signal?
yes, from the first O2.
MR-S Turbo
Cheers Ian.  You will be glad to know the intercooler is working fine also   s8) 8) s8)
Cool, glad you got it installed so quickly.  s:D :D s:D
