need shifter pivot cup!
Started by Anonymous, September 26, 2005, 22:51
does anyone know where I can get the little white plastic thing that has the ball bearing in it that goes on the shifter? i messed mine up installing my Fidanza short throw.
MR.T???
good luck  s:wink: :wink: s:wink:
mr. t only sells the whole shifter which is either $148 or $348. i forog twhich one but i could buy a whole new TRD shifter for that. any advice?
sorry i've got alot of stuff  s:roll: :roll: s:roll:
Quote from: "mefarri"mr. t only sells the whole shifter which is either $148 or $348. i forog twhich one but i could buy a whole new TRD shifter for that. any advice?
It's not really a part that wears out so people would need replacements, so it's very VERY unlikely that anyone else would be selling those. I'm afraid you have to buy the whole thing, unless you can get a used one.
im thinking about calling B&M.
Quote from: "mefarri"I'm thinking about calling B&M.
That's your best bet as they may let you have one if you explain your predicament   s:wink: :wink: s:wink:
Jap GT300
I have a complete shifter cage available if you still need it.
Quote from: "Jap GT300"I have a complete shifter cage available if you still need it.
The bit needed is actually "part of" the gear stick. I noticed the B&M stick comes with them on. Maybe they can supply...or rant and rave when you explain you didn't want buy their expensive one   s:wink: :wink: s:wink:
I can confirm MrT doesn't supply. Only the cage and gearshifter as one complete assembly. I asked before I did mine, wanted a couple of spares, just in case, so under the circumstances I went particularly carefully.
Jap GT300
The cage I have is complete with stick and mechanism.  I don't know if it is of any help?
you know i don't need th cage, but how much just for the shifter?
