hardtop
Started by Anonymous, October 1, 2005, 17:24
hi, ive just spent a frustrating afternoon fitting my hard top. the top was on the car when i bought it and this is the first time ive refitted it. basically the passenger side is sitting slightly higher than the drivers side at the back. also it is sitting slightly back at the door pillar, i.e. it seems as if the whole top should be 5mm further forward. it aligns perfectly on the front and side clamping points, but there is very little  resistance when closing the side clamp. i can actually see daylight if i look at eye level at the seal! ive tried repositioning the top and to no avail. the hooks are definetly into the brackets at the back. anyone have any ideas? thanks.  s:( :( s:(
all the clips are adjustable, so open them all up and unlock the little latch inside - then turn the bolt so they are at their most extended... then put the roof back and position it so it fits with all the clips open.
Then, start to tighten the bolts a few turns on each clip and work your way around... increase and loosen the bolts as you go around until you have a good fit.
darrenjuggins
Nelix - Do not adjust anything to start with......
Ok - mine goes on in about 2 mins with two people, so something is definately wrong if its taken you all after noon.
Heres a run through of what to do :
(I will presume you have dropped the soft top into it's down position)
Ensure the rear widow has been unplugged and that you have threaded the hardtop lead through, before starting - its much easier.
1. Open the windows fully
2. Push Sun visors all the way forwards.
3. Undo all the clips on the hard top
4. Now Position the hard top and the back of the car and now get two people, one either side to move it into position.
5. When its over the car, you ensure that the slides at the back of the hard top fit under the silver catches each side, it should be obvious if they are not.
6. Once they are in position, all the clips should be aligned, go round the car and ensure all 4 clips are in the down position.
7. Now wind up the windows and everything should be nice and snug.
8. Connect the heated rear screen wire.
If you follow the above, the top should fit as purchased, there should be no reason why you need to alter the clips, nothing will have changed on the car and playing with the adjustments, will only complicate things.
Try what i've said in the morning, with two others, so you can ensure all the clips are in place.
After 1 or 2 sucessful fitting, you should be able to do it with only 2 of you. (Before shaun comes on, I know you can fit it yourself, but we are not all over 6ft tall   s:D :D s:D  )
Hope this helps and sorry for the step by step instructions, but I thought it would be most useful.
Darren J
Darren A. Juggins
I assumed he would have done the above since its taken him all afternoon - afterall, you cant put the soft top up with the windows down etc so its common sence to do the same routine when putting the hard top on   s:roll: :roll: s:roll:
thx all, ill try again
hey,
its probably a good idea to make sure you dont have soft top "Ears" sticking out when the soft top is folded down. This could be making the hardtop sit higher than it should at the back.
Richie.
darrenjuggins
did you get it on nelix ?
Darren A. Juggins
its on darren but im still not happy, need a dry day to try again.
darrenjuggins
Hi Nelix,
I'd say pop round - but your just a tad far away from me.
Let us know when you have refitted on a better day.
Darren J
Darren A. Juggins
lol thx darren, me and the better half(by far!) tried again 2day. checked the soft top was ok and loosened all the catches, it still sits slightly high on the passenger side even b4 you clip it on. i tightened the clips a touch but its still not 100% right. alas its a trip 2 mr t tomorrow!
darrenjuggins
Hi Nelix,
Sounds like the best option, you may also be able to see another 2 with a hard top on for comparision, it's always difficult to see what the problem is when things are wrong, then you will see another car and bingo !
Well best of luck and lets hope they can fathom it out.
You have took the little leather booties off the side posts ?
anyway, i'll stop guessing and hope that Mr T sorts it all out for you tomorrow.
Best of luck
Darren J
Darren A. Juggins
lol yes, only had 1! thx again, craig
did you ever get this sorted out mate?
If you need a comparison to my hardtop, im only about 25mins from paisley.
Richie.
cheers m8, still sits a little high 1 side. good indian in helensburgh, we should arrange a scottish meet! could pop over and compare and have a chat if your about at the weekend?
Quote from: "nelix"cheers m8, still sits a little high 1 side. good indian in helensburgh, we should arrange a scottish meet! could pop over and compare and have a chat if your about at the weekend?
Im working 7am - 7pm tomorrow and saturday, but I dont start till 7pm on sunday so I'll be around during the day if you want to pop over?
I think a scottish meet would be a good idea, at loch lomond or something? perhaps better off saved for a nice sunny summers day tho!
As for the indian, I assume it was akash you were in? it is indeed good!
Richie
lol m8 im off sat, working 7 till 7 sun!
lol, guess you work shifts too then?
alas yes
