rear tyres (yokohama)
Started by Anonymous, October 5, 2005, 19:33
just had to change the stock rear tyres only done 10k totaly bald around the outside edge is this about right?
didn't want to mix the tyres so just got the same ones, can anyone recomend anything better when i change them all?
Quote from: "mk3_red"just had to change the stock rear tyres only done 10k totaly bald around the outside edge is this about right?
Mine are still just about ok and I have done 21k (and I hammer around corners)  s:wink: :wink: s:wink:
If i were you i'd have the tracking done when you change, sounds like its out.
Bongo
I managed to get through a set of stock Yokos in 7k   s:oops: :oops: s:oops:
Quote from: "Bongo"I managed to get through a set of stock Yokos in 7k   s:oops: :oops: s:oops:
s:shock: :shock: s:shock:  They must be a lot softer than the stock Bridgestones.
