tte exhuast installation
Started by Anonymous, October 14, 2005, 15:25
been trying to install my tte exhuast, i'm having the hardest time because the part didn't really come with any instructions.  i'm wondering does the bracket for the second tip, suppose to be install in front of the rear sway bars or behind....... or do you have to drill a new hole?  i'm not much of a mechanic and any help would be greatly appreciated.
thanks
Quote from: "Tem"http://spydermagazine.com/2002/July/tte/tte-review.htm
I know about the link.... but it doesn't say anything about where to put the bracket.
cant find a picture at the mo but theres a bolt on the RHS that you use to mount it off from, if i remember rightly its on the bumper bar struts that run forwards from it
on the right of the picture you'll see the attachment point for the sway bar. just above it on the picture is a black dot, remove it and use that as a bolt on point, i was wrong in my previous post about removeing a bolt and useing that to mount from
 m http://www.spydermagazine.com/2001/April/DCP_0323.JPG m
Tht's one monster picture Stu  s:shock: :shock: s:shock:    s:shock: :shock: s:shock:    s:shock: :shock: s:shock:
sorry left it big on purpose, will make it a link though
someone on the SC metion to me that i should attach the bracket to one of the bolts on the sway bar attachment.  has anyone else done that?
Quote from: "MrGreen"someone on the SC metion to me that i should attach the bracket to one of the bolts on the sway bar attachment.  has anyone else done that?
gotta go to work now but i'll take a picture of mine tomorrow
The bracket goes on the back bolt of the swaybar bracket.
There's ascan of the instructions HERE
Quote from: "kanujunkie"
that would be super!  also can you give me some pointer on how to align the tips?  btw you gents on this forum are more friendly than those guys on SC.    Thanks
Quote from: "FairportSpyder"The bracket goes on the back bolt of the swaybar bracket.
got your post on SC but wasn't sure by looking at the picture.  thanks for your continue help.
I didn't notice I was responding to the same person again, and I type so slow I missed your post about SC.
I know that was a pretty lousy scan I posted, but the instructions clearly state:
"Fur Zusalzhalter originate Schraube fur Stabilisator verwenden"
I don't know it that helps you, but it sure didn't help me.
Quote from: "FairportSpyder"I didn't notice I was responding to the same person again, and I type so slow I missed your post about SC.
how did picture instructions came with your tte?  all i got for instruction was one piece of paper in eight different lauguages.
Quote from: "MrGreen"how did picture instructions came with your tte?  all i got for instruction was one piece of paper in eight different lauguages.
I got one piece of paper in 3 languages, with the picture on the back.
Don't know it it's any better than what you have, but here it is:
Instructions
Instructions
i see...... the link to the pic is much better.  it seems like the end tip of the bracket is facing towards the rear tire.  so that mean when attached to the muffler, both the muffler attachment tip and the bracket tip will be facing the same direction.  is my assumption correct?
Quote from: "MrGreen"i see...... the link to the pic is much better.  it seems like the end tip of the bracket is facing towards the rear tire.  so that mean when attached to the muffler, both the muffler attachment tip and the bracket tip will be facing the same direction.  is my assumption correct?
Yes, you've got it correct.
I have the remus exhaust (same as TTE but Round tips) I found it easier to fit exhaust with tips attatched to brackets and clamps all loose enough just to move tips a little. This will give you chance to align them. Then tighten each side up. Mine took a bit of fiddling but sorted in the end. Hope this helps.
