Water 'sloshing'?
Started by Anonymous, October 27, 2005, 10:14
I drove my car last night after not using it for about four days.  It has been raining quite heavily in the intervening period and the car lives out on the drive.
The first time I used the brakes moderately heavily, I heard what sounded like a considerable quantity of water rushing forwards towards my right ear!  It then sounded as though the water ran downwards.
It happened again, a little while later, when I braked quite hard on a downward slope, and that was the last I heard of it.
I guess that my question is : Is this normal?
If not, is water getting in to somewhere where it shouldn't, or is there a blocked drain somewhere?
I've had the car for less than two months and it has around 1500 miles on the clock.
It's not normal, but it's quite common and easy to fix.
Please use the search for "drain" as this had been covered many times  s;) ;) s;)
Good call!  I wasn't expecting this problem on a car which is almost brand new.  However, in my case, I found that the rubber flab on the driver's side was very neatly sealed shut with a white wax - presumable some of the protection which is applied to the car for shipping.
Incidentally, is anyone else concerned at the amount of distortion required to the lugs on the vent covers in order to prise them loose?
Is this the way Mr.T would remove the covers, or is there some way (no doubt, involving a major dismantling of the interior of the car) of accessing the white plastic clips from behind in order to release them?
Perhaps this is why someone else has been told that the roof needs to be removed in order to fix the problem?
darrenjuggins
Yeah they do take a bit of force getting off, but I've had mine on and off a few times without any damage.
Unfortunatly if you park under trees, etc then the drains do become blocked easily.
Darren J
Darren A. Juggins
Ernie Ball
I damaged one of my new 03 vents when taking it off.  The damage is not visible and is slight, but it does happen.  Basically, part of the plastic that holds the plastic rivet gave before the rivet popped out.
Had this one myself the other day, uneasy feeling at first seeing as theres over a grand in electronics in the back  s:? :? s:?
Peoples, before winter hits, do check your drains, mine were actually stuck shut and had a load of mud behind them! do it now before you find your own slosh!
Quote from: "kanujunkie"Had this one myself the other day, uneasy feeling at first seeing as theres over a grand in electronics in the back  s:? :? s:?
Yes I have amps under the rear bins  s:? :? s:?
