Two injectors in two weeks?!
Started by Leggy, November 10, 2005, 14:00
Leggy
I posted a topic two weeks ago, "New injector, should I be worried?"
The 2's been in again twice this week, coughing and spluttering in between. It turns out I need another injector!
Slacey very kindly said I had nothing to worry about when the 1st one went, but now 2 in two weeks  s:!: :!: s:!:    s:shock: :shock: s:shock:    s:roll: :roll: s:roll:
Is there anything that can be causing this?
Alex
00 Silver / Black Leather / Toyota UK Front spolier, Side skirts & Rear bumper extensions / Hardtop / Mongo\'s / Corky\'s / Cusco Front Tower Brace/ Custom twin Exhaust / 03 Side Vents / Che\'s Header. Sadly a distant memory!
There are quite a few things that can cause an injector to fail - and it depends on how exactly it fails..
Electrical failure (failure of the coil) could be caused by bad wiring - shorts, high/low driver current, and depending on the type of injector (some use the fuel to cool the coil) corrosive fuel 'cleaners' stripping the coil protection and causing an internal short.
Mechanical failure can cause if the fuel delivery mechanism (the solenoid, pintle if ours have a pintle etc) gets blocked/jammed/clogged.
The only way of telling is to get the old injector tested by a refurbishment company and/or flowtested to see how badly it was performing.
It could even just be old age..
You'd need to know what part of the injector failed, really, to make any kind of diagnosis as to whether you should be worried or not.
Not sure how much stock injectors cost - but if it's not that much, it's probably not worth worrying about, just replace them when they go. If the same injector goes twice, though, then you have a problem that needs investigating.
Leggy
Thanks for the quick reply!
Luckily, I took out a two year Inchcape warranty when I purchased back in March this year. They keep paying for the work to be done each time, so I suppose I shouldn't be to worried.
I think they mentioned that an injector cost around £300 + fitting.
UNLUCKY!
Quote from: "Leggy"I think they mentioned that an injector cost around £300 + fitting.
You can get FOUR (used) stock injectors for some $50  s8) 8) s8)  They are useless junk for most people who upgrade...
(I know Toyota won't buy used stuff, but just so anyone doesn't worry about it too much after warranty's over)
Quote from: "Tem"You can get FOUR (used) stock injectors for some $50  s8) 8) s8)  They are useless junk for most people who upgrade...
Yup, cheap as chips as we say over here.. If you can't find a set of used, you can also get your old ones remanufacturered (though that'll cost more, depending on what is wrong with them - but that process does incude a flowbench to check they flow to spec).
I'm fairly sure swapping them out on our cars is a piece of cake, right Tem? (Relatively speaking, I mean - on the 300ZX you have to either remove the entire intake manifold or dremel bits of it off to get clearance)
Quote from: "aaronjb"I'm fairly sure swapping them out on our cars is a piece of cake, right Tem?
Yeah, it's very easy.
0) Unplug the battery or remove the EFI fuse, to let fuel pressure out
1) Take the plastic valve cover cover off, two nuts and two clips
2) Raise the fuel rail off, two 12mm bolts and just lift
3) Put some old rag under the injector you wish to remove and pull it off
...reverse to install...and it doesn't harm to replace the O-ring from the injector, though I never did that...
Leggy
I was told 1.5 hours by Mr T   s:shock: :shock: s:shock:
They tell you anything! Well, me anyway.  s:oops: :oops: s:oops:
Alex
Quote from: "Leggy"I was told 1.5 hours by Mr T   s:shock: :shock: s:shock:
I just looked at the BGB, and I can't figure out where that would come from...but then again, the list hours are always a bit high.
The manual tells to remove the STB and PCV hose, as well as the whole injector wire harness, which hardly adds much time anyway...
Bongo
You're forgetting that each job must have enough time allowed for at least 3 tea breaks and 5 scratches of the arse.
On the other side, if they (well the warranty company) are paying, then who really cares? They probably think that's what they can get away with charging and that you won't query it because you're not paying for it...
