Precat- help me understand
Started by Anonymous, November 14, 2005, 14:19
Ok, I just purchased a used (near mint cond.) 2000 Spyder. It has 44,000 miles. Then I get on here and read through these precat failure boards. So, now I'm quite insecure about my purchase and am considering buying a 60 month 100,00 mile warranty for $1300.
Bu can someone explain to me how something in the exhaust line goes backwards into the engine? I'm having problems figuring out the physics of how something from the cat can go backwards into the engine??
Thanks for your help!
do a search and you will find all the info mate, every detail of the pre-cat stuff is on this site somewhere
it's not in the exhaust as such, but the pre-cats are located in the exhaust mainfold. here in the UK it's easily fixed, by removing them, but in the US you need them for you emisions testing   s:( :( s:( , personnaly i'd take the warranty to be on the safe side. Pre-cat failures are few and far between, but alot of people on this site are glad they got the warranty for other issues.
hope this helps
Quote from: "extremeMR2"but in the US you need them for you emisions testing   s:( :( s:(
I think that might only be true in Cali.. not 100% sure though - if one of our overseas bretheren doesn't pop up, the folks over at Spyderchat are sure to know for sure  s:) :) s:)
Florida doesn't do emissions testing anymore.  I don't know what other states do, but there are some others besides California.  A TRD header is the best way to go, IMO.  No problems, not too loud as long as you don't put a really loud exhaust on, too, uses stock sensors and heat shield, makes a little bit of midrange power.  I just sold mine, but they pop up now and then.
In the U.S., Federal law trumps state law, and Federal law says you can't tamper with emissions equipment. So decatting isn't legal in the U.S. Doesn't stop any of us from decatting, but it does mean that you generally have to do it yourself, as no certified shop would do it.
From California to Florida, Texas to Maine, no decatted Spyder has ever failed an emissions test (at least, not as a direct result of decatting). The main cat does a very good job and will get the owner through the process. The inspectors do not look for the presence of precats and will not notice their absence.
