Spacers for replacement speakers
Started by Anonymous, November 16, 2005, 11:02
The existing speakers are a strange hybrid of speaker and spacer.
Rather than messing about with MDF and a jigsaw if you don't mind cannibalising the existing speakers then just cut through the struts that extend from the speaker magnet to the inside of the spacer part with a pair of snips, this leaves the speaker cone attached to a cardboard ring on the front face of the spacer, pop a thin screwdriver between the cardboard ring and the spacer and the whole lot can be prised away leaving a spacer which the new speakers can be screwed to and which will then fit into the car with the existing fittings.
Ernie Ball
Don't these look like they might do the trick?:
They do, and when I bought my speakers I ordered a set of those that were supposed to fit the Roadster ... unfortunately they didn't, which is why I ended up cannibalising the old speakers.
Wildcard
Here's a thread with pictures showing how to modify the existing mounts to work.
 m http://spyderchat.com/phpBB2/viewtopic.php?t=40000 m
Ernie Ball
That's what I ended up doing.  I had bought a set of MDF spacers (Buster's originals, I guess) but the holes were too big for the speakers.  As it turns out, cannibalising the existing speakers is fine, although I did gulp a little as I destroyed the first one.  s:shock: :shock: s:shock:
I've got some MDF left from when I did mine. If anybody wants some I will be more than happy to jig-saw a set (for say £15 delivered UK) to help recover my costs and give a donation to the club.
As Steve says, speaker body diameter size will need verification.
