rear window heater
Started by Anonymous, November 17, 2005, 14:50
hi a new owner my hard top demister not workin do i need to connect any connections as there is a socket on the side of the hard top...cheers thanks   s:oops: :oops: s:oops:
Darth Paul
This has been discussed recently in the maintenance forum. Have a look.  s:D :D s:D  Try 'heated screen' in a Search.
Bill, welcome to the club to start with  s:D :D s:D
if you go into the cubby holes behind the drivers seat, then remove the small pop out side panel to the right of the car, you'll find in there a cable mounted on the panel, this needs to be connected to the hardtop, you should have a small extension cable to connect the HT to this
I have just been fitting my hardtop and found all the information in your Toyota handbook with diagrams.
