electric mirror not working
Started by Anonymous, November 18, 2005, 16:52
hi all. i noticed 2day that my drivers side electric mirror has stopped working. the passenger side is fine and as far as i can tell they both work off the same fuse, so it cant be that. any ideas anyone?
heres the wireing diagram, the power comes from the radio fuse and yes theres only one power source for the mirrors
 m http://www.tandridgecanoe.co.uk/roadster/mirror.pdf m
chances are its the switch, as theres 2 motors in the mirrors and if ones dead then the other would still work, but if both are dead then the chances are its the switch, If you have a multimeter then it'll be a 2 minute job to bell it out, if not find someone who has one and have a go
thanks kanu
alternatively, could you pop the fuse out and swap the connectors over so that you are using the switch for the passenger side? that would be a quick way of ruling out if its possible?
Quote from: "Richie"alternatively, could you pop the fuse out and swap the connectors over so that you are using the switch for the passenger side? that would be a quick way of ruling out if its possible?
try reading the title Richie, reads mirrors, not windows!!!
