Gearbox bearings part no?
Started by spyderman, November 23, 2005, 08:04
spyderman
Hi there, im looking into reconditioning my gearbox.
The problem is, Toyota in my country does not have in stock any of these bearings, so they told me i need to place an order, a procedure that will take an easy 3-4 weeks. It is too long to stay without a car i guess, just waiting for a few bearings to arrive.
Anyways, long story short, a bearing manufacturer SKF, more than likely has the bearings that im looking for in stock, and in 1/4th of the price Toyota is asking for, but all i need is to give them the part numbers, so they can check the availability of the specific bearings.
Does anyone happens to know the parts number of the these bearings, or anywhere i can get them?
Thanks..
As you set out for Ithaka
hope your road is a long one,
full of adventure, full of discovery. Cyclops,
angry Poseidon - don\'t be afraid of them.you\'ll never find things like that one on your way
as long as you keep your thoughts raised high
-SOT-
Sorry, no...but if you get them, please post them  s8) 8) s8)
spyderman
Tem,
i will remove the gearbox on Sat morning.
I will see, if it is a bearing problem, i will try and find out all the aftermarket SKF bearings to replace them.
If it is a gear problem on my car, LA gear probably, than i will go for a second hand one, and i will not bother in reconditioning mine.
Anyways, lets see   s:roll: :roll: s:roll:
-SOT-
Jap GT300
I can do a good price on a 5sp gearbox
my car goes into mr t on monday to get 3 of the bearings replaced on the gearbox - if the details are on the invoice il post them on here.
Richie.
spyderman
Quote from: "Jap GT300"I can do a good price on a 5sp gearbox
Adam,
i wish i could get your gearbox. The thing is, as you know, i do live in Cyprus, and shipping charges would be too high, i guess.
Plus, im left without a car, and that means if i do get your gearbox, i will have to wait acouple of weeks at least.
Anyways, you can PM me a price if you want, including shipping, and i will take into considerayion your offer    s:wink: :wink: s:wink:
-SOT-
I never got any of the part numbers for the bearings sorry, I still have no idea what bearings exactly they were changing.
Did you ever come to a resolution?
spyderman
unfortunately my car is still on the jack with no gearbox. im driving my brothers Honda Civic at the time being.
no bearings found in our market, not even in SKF.
that means i will have to go for the second hand gearbox i found here, with a cost of 250 GBP. Of cousre it's a risk, a second hand part will always be a risky one, you don't know what's inside, and how long it's gonna last   s:roll: :roll: s:roll:
-SOT-
If its the one which adam here is selling, I think you could probably buy it with a degree of confidence.
Richie
So this info did you no good then?
 m http://www.spyderchat.com/phpBB/viewtop ... ht=bearing m
spyderman
Iam always late in checking replies in my posts
Yes, this is the part i was looking for.. unfortunately i bought a second hand gearbox today since as i said, i couldnt find this part in our market
anyways, is this the most common part that is causing problems to gearboxes?
is this logical to get a took took sound just from a bearing, than a whinning noise?
when i disassembled my gearbox, it was obvious that this bearing was defective, but i could not spot any other problem than a normal wear on gears..
-SOT-
Quote from: "spyderman"is this logical to get a took took sound just from a bearing, than a whinning noise?
that was the symptoms mine had - all repaired now tho  s:D :D s:D
