fitting 03 wheels on pre-O3 car
Started by Anonymous, December 9, 2005, 13:52
Hi folks,
Firstly apologies if this has been discussed elsewhere. I've tried various searches but haven't found this particular question.
So, has anyone fitted 03 wheels (15F 16R) to a standard pre-03 car (15F 15R)?
Any thoughts on potential problems or even benefits?
Thanks in anticipation.
Del
yep markiii runs his pre 03 with post 03 rears all the time, works fine
Thanks!
That has to be the quickest reply I've had on any forum.
Friday huh?   s:lol: :lol: s:lol:
Liz
I have got them too, no problems at all.
I have got them too (post 03 rears) but I use my original 15" rears on the front with a 195/50 tyre. I wanted to go up to a 195 with fitting the wider rears and IMO a 195 sits better on the wider rim than it does on the standard 6" wheel even though I know some people who have fitted them without a problem.
You will have far fewer choices of matching tyres and the stock 16" rears  are heavy.  RE040s came standard in most of the US.  They are a quite good but  lose their initially great  grip after 10-12K or sooner if your driving is extreme.
Best: I forget the sizes, but you can get Potenza S-03s that work great.  Awesome tyres that keep their grip because they are dual compound.  Cons: cannot be rotated front to back or side to side, rears are expensive.
Quote from: "Beanie"You will have far fewer choices of matching tyres and the stock 16" rears  are heavy.
That was the first thing that came to my mind as well...
If I was going down that route, I would look for aftermarket solutions and may I suggest wider tyres at the front as well.  I have a feeling understeer will become more apparent with just the rears modified.
just as a note see  m http://www.mr2roc.org/phpBB2/viewtopic.php?t=9293 m  regarding a set of 16 inchers for sale
Thanks for the replies everyone.
Some food for thought there...
Del
