unichip -help needed
Started by Anonymous, December 20, 2005, 16:42
ive just bought a unichip with plug and play adapter but on the instructions it says to remove the four connectors going into the ECU then to connect the two plugs from the harness in to the ECU.
do i then need to plug the other two plugs back into the ECU, or just leave the two from the PnP?
i have searched but could not see anything, except for how easy it was to install!!
Quote from: "bburkie10"ive just bought a unichip with plug and play adapter but on the instructions it says to remove the four connectors going into the ECU then to connect the two plugs from the harness in to the ECU.
Yes you do need to reconnect the other two back onto the ECU  s:wink: :wink: s:wink:
That was the only difficulty I had! The instructions assumed a 2 port ECU!
<edit> or was it the other way round   s:? :? s:?  Something was 2 that should have been 4, or 4 that should have been 2> </edit>
cheers, thanks. and then the two plugs that were in the ECU plug into the harness?
sorted!! i figured if they were ment go fit they would  and if they didnt fit....they would`nt!
