is it possible?
Started by Anonymous, December 27, 2005, 17:20
i have got the mr-s which come with a jap dvd and sat nav system double din head unit and tv, i was thinkin of replacin the headunit with a dvd head unit as the jap one cant b chipped, is it possible or easy to wire up the new headunit to the standard tv or is the wirin in the imports different?
think you want to ask this over at SC Maz, pretty sure its been done over there.
LeeUK
You would need to take a look at the connections into the screen.  If they are AV which would be handy, you could experiment by plugging a PS2 into it or something similar just to check it works correctly before dishing out for a new Headunit.  If you need a hand give me a shout.
[size=100]JELBE[/size]
[/color]
cheers hun,
i wanna get rid of the head unit and put in a dvd one, halfords said they would connect to the tv free of charge but just wondered if the connections were different to the uk spec one
LeeUK
Unless you've got a good deal don't get ripped off in halfords have a look at:
http://caraudiosecurity.com/catalog/index.php
http://www.bassjunkies.com/index.php?area=home
http://www.mobiletoys.co.uk/
You will get a great service off the above if they can give you a better deal.....
.....I should be on commission.  s:roll: :roll: s:roll:
[/color]
