How Difficult To Replace The Aerial & Motor Myself?
Started by Anonymous, February 17, 2006, 14:42
My stock one doesn't go up and down, stays up all the time, I have been quoted £100 plus out a garage but I have managed to source a second hand one for £25.00 and my question is how easy to fit this myself?
I aint the best at tricky jobs but if it is just a matter of removing the wheel etc then I could maybe give it a go myself.
You have to remove the wheel, plastic arch liner then the rear wing itself. Not too difficult, but only you know your mechanical limits!
I think its wise to throw in a safety warning too, to ensure that your car is properly supported (ie not just on a jack) if you're removing wheels.
Sorry if this sounds obvious, but we don't want you to damage your car  s:lol: :lol: s:lol:    s:wink: :wink: s:wink:
Be safe.
How difficult is it to remove the inner and the arch? I have done things like this before, easy to come off but a btard to put back on and get it lined up.
How long do you reckon it would take from start to finish?
So defo no no with just a jack, I had to paint all the callipers with just the jack holding the car up???
See here for what happens when you don't support the car properly when changing the aerial
 s:oops: :oops: s:oops:
Use proper jack stands, and you'll be ok. Shouldn't take much more than 2 hours, I reckon. And that's not including dropping your car on it's brake discs.  s:wink: :wink: s:wink:
Jesus Chr1st, axle stands for me i think Ekona, not going through that, I always make bad things happen when I try these jobs.
Ekona how difficult is it to get all the panels off and the new aerial fitted etc, are there any nasty bolts/screws to get too?  i'm just doing a straight stock replacement.
i would have attempted this job with just the normal jack as well so glad you showed me this post.  s:shock: :shock: s:shock:    s:shock: :shock: s:shock:
It's really obvious what to take off and where, nothing's awkward or anything. It's about as straightforward as a job can be on the '2.
