more power
Started by Anonymous, January 2, 2004, 19:18
can anybody help me with advice on upping the bhp on a standard roadster (manual). i have been quoted £238 for a "super-chip" by mini sport which they say will add 7 to 10 bhp.are there any other "chips" on the market that are better, or any other mods that can be done without spending loads of £££££££££££££££££.
hope you can help.thanks.  s:!: :!: s:!:
Quote from: "mrloz"can anybody help me with advice on upping the bhp on a standard roadster (manual). i have been quoted £238 for a "super-chip" by mini sport which they say will add 7 to 10 bhp.are there any other "chips" on the market that are better, or any other mods that can be done without spending loads of £££££££££££££££££.
Superchips are rubbish. It wouldn't give that benefit. Superchips should only be put on Turbo diesel cars - and then theres FAR better and more mechanically sympathetic ways of doing things!
I'd save it and spend it on other mods, maybe an induction kit, sports cat or de-cat, an exhaust - something like that.
Best Regards,
Gareth.
SteveJ
We have a demonstrated increase from 138bhp (stock) to 159bhp using the Dastek Unichip + a'Pexi intake and tuned on the rolling road at Millway
The car in question is Martin's (mph) and was done as part of the prep for his custom turbo install.
Quote from: "SteveJ"We have a demonstrated increase from 138bhp (stock) to 159bhp using the Dastek Unichip + a'Pexi intake and tuned on the rolling road at Millway
Yep, the Dastek is a much better bit of kit, it costs a lot more than a Superchip but at least you get proper results.
Gaz.
I thought he only dynoed the car after the install...?
I'm sure the 159hp is correct, but I doubt it had 138hp stock. For comparison, here's my stock dyno:
 m http://koti.mbnet.fi/temmeke/tmp/dyno.jpg m
(about 20.000km's at that time and only had the 1st year service done, nothing else)
mph
Quote from: "Tem"
Could always ask me   s:wink: :wink: s:wink:   The two dynos for the before & after installation of the Unichip where performed on the same day in what I'd consider stable atmospheric conditions. I tend to quote the 22bhp increase rather than the absolute numbers to avoid direct comparisions with other cars.
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
Quote from: "mph"Could always ask me   s:wink: :wink: s:wink:
I was kinda sure you'd reply  s;) ;) s;)
Didn't find the dyno anywhere and remembered it only had the after-curve  s:oops: :oops: s:oops:
Quote from: "ENVY"I'd save it and spend it on other mods, maybe an induction kit, sports cat or de-cat, an exhaust - something like that.
Best Regards,
Gareth.
Can you supply a sports (high flow) cat by any chance Gareth?
crankshaft
Hi;
I am a newbie on this forum, and have read thru as many of the threads as I can, trying to pick up the lingo !.
Like mrloz, I am also looking for some advice on bolt-on power gains and understand that the Dastek Unichip is supplied un-programmed, and that it needs to be individually setup on a dyno ??!!
If this is correct, and I don't have easy access to a dyno, are there any known default configurations which could be used as a general starting point ??? and is there software supplied which can be run on a laptop to modify the settings via a USB port ???
Also, is the Apexi intake which was mentioned simply a replacement filter or is it a complete new intake system ???
PeterC
2001 SMT - Pete
mph
Quote from: "crankshaft"Hi;
PeterC
The £400+VAT price for the Dastek includes fitting and mapping on the garage's dyno.
The A'PEXi is a replacement from stock filter box.
crankshaft
Thanx so much for the info, is this the a'pexi filter ??  m http://www.racerwheel.com/engine-air-filter-apexi.html m
Is it a drop-in replacement or does the original airbox need to be removed or modified ?
2001 SMT - Pete
The Apexi system you hear talked about is a complete replacement for the stock airbox, I'm not sure if they do a drop in filter, but I don't think so.
Hi ENVY
i like the splitter of red MR spyder in the pic of your website. Is it possible to buy it and where?  s:wink: :wink: s:wink:
Maurizio
juansolo
Quote from: "mrloz"...or any other mods that can be done without spending loads of £££££££££££££££££.
IMO real noticable power increases never comes cheap and I refer you to my other post in the 180hp thread regarding why you want to do it.
Hi thanks for all the info re the uni-chip.i
i think at £400 fitted is pretty good for about 22 extra hp.
i am from Manchester does anyone know of a good garage that fit the Dastek and Apexi filter? once again thaks in advance for the info. MrLoz.
Quote from: "crankshaft"Thanx so much for the info, is this the a'pexi filter ??  m http://www.racerwheel.com/engine-air-filter-apexi.html m
Here Crankshaft, try this and you can see all the fit and the Apexi intake as well
http://www.spydermagazine.com/2000/Sept/Apexi/apexi.htm
what you had was the intake only, but you need the ducting as well   s:D :D s:D
