Ipod link for pre-facelift stock Sony HU
Started by Anonymous, March 15, 2008, 09:57
Still new, so please don't shout...!
Does anyone know (and I'm sure the answer is yes) if the stock Sony HU in my 2000/X '2 will be able to control my ipod nano (2nd gen) AND support artist/title info if I buy one of these:
 m http://www.ipodcarkitdirect.co.uk/iPod_ ... IPOD001%29 m
I have had a Dension Ice Link in another car, which was good, but my stock BMW CD player didn't support, which was a blow, after forking out a ton for the Dension kit...   s:cry: :cry: s:cry:
This unit looks, on the surface, much better value, but is it fully functional with the stock HU? Also, is tha sound quality any good?!
Cheers muchly
Alex
enid_b
i had the connects 2 system for a while. they are now available on ebay for about half what i paid for it.
to be honest i knobbed it off and got an alpine HU after a while, for the following reasons.
The sound quality is fantastic. its hard wired in so much better than the FM transmitters and the like.  its a small box with 2 wires, so you can install it in approx 35 seconds, it just plugs into the changer plug on the stock HU.
the downside was that despite its claims of operating the ipod from the HU, i didnt find that it worked.  it was easier to set up a playlist and then just press go.  navigating was a nightmare, but im not sure if that was just my individual head unit.
so if u just want good sound from pre selected songs/albums then this is the system for you.
if you want full control of your ipod, i would look elsewhere
HTH
E   s:D :D s:D
I've just bought one of those Connects2 units off eBay brand new for £20 to go in the Griff (to a Sony unit). I'll be fitting it later today, so I'll report back on the findings. TBH, I'm not too concerned about controlling the iPod from the H/U but I'll have a go at it.
Hmm, will this work with the iPhone?
And also charge it up?
enid_b
not sure if it will work with the iphone, the connects2 has been around for a while, and is quite primitive.
if the iphone takes the standard ipod lead and connector then you may have a chance.
yes it does charge as it goes along
E
Right, just fitted (which would have been a doddle in any other car  s:roll: :roll: s:roll:  ) and it works just fine. I did think though that you could control the iPod directly, which you can't - it all has to be done through the H/U which works well enough. Anyway, for £20 I'm happy.
Quote from: "enid_b"i had the connects 2 system for a while. they are now available on ebay for about half what i paid for it.
the downside was that despite its claims of operating the ipod from the HU, i didnt find that it worked.  it was easier to set up a playlist and then just press go.  navigating was a nightmare, but I'm not sure if that was just my individual head unit.
HTH
E   s:D :D s:D
Thanks for the advice - the BMW / Dension set-up uses playlists as if they were the six CDs in a changer, so it's slightly controllable from the head-unit. I think the key here is to get one off the 'bay for a few quid and give it a go... if it's cack, then I'll consider the Alpine route.
enid_b
thats how i did it mate.
good luck
E
So is this iPod link just the Radio tune-in version, or does it actually patch in directly to the tuner/radio/cd player?
enid_b
zero, this discussion is about a connects2 system. its hard wired between ipod and hu via the cd changer socket so has much better sound quality.
E
The connects2 can be fitted without even removing the head unit as the three connectors you need can be access by sticking your head in the footwells.  The standard HU doesn't have the ability to display track names so I'll probably put my other Sony head in eventually but you are able to change tracks using the forward and back buttons as if there's a CD in the drive, not the best solution on the market but cheap and can be installed with no tools   s:wink: :wink: s:wink:
stv2100
I used the following parts from ebay and dash mounted my ipod. Works a lot better than the connects 2 and the dension i-link on the old sony head unit.
IPOD to 2x Phono/ RCA Charging Adapter
Sony unilink car stereo auxiliary input adapter
All available from the same seller (exclusivepart) from Hong Kong.
Silver 00, Hardtop, corky\'s breast plate, BC Coilovers, FTSB
Have you got a link mate as a decent mounting kit would be great?
Tim
stv2100
Quote from: "shippyt"Have you got a link mate as a decent mounting kit would be great?
Tim
I fabricated a mount myself based on the Brodit proclip bracket and modified an adjustable mobile phone holder for the cradle. If you don't want to make your own you can buy the bracket and passive cradle (quite expensive) from ipodcarkitdirect.co.uk
Cheers.
Thudd
Would the Sony unilink car stereo auxiliary input adapter work on the post-facelift HU?
I don't want to waste cash on an incompatible part, even if it is only £15 with shipping  s:) :) s:)
Thinking of getting one of these, wiring up a socket, and using the iPhone in a vent mount by the wheel.
post facelift is made by Matsuhita who own Panasonic so no it won;t
Thudd
Bah!
Thanks.
