fickle fuel filler...
Started by Anonymous, February 5, 2004, 17:25
Hi people,
This is my first time here so go gentle with me!
I've got a '00 MR2.  Normally I have no problems with fuel filling but occasionally, even when using my normal petrol station/pump the pump will cut out continually.  Has anyone else experienced this?  Tried all the normal sort of stuff like filling it slowly, turning the pump handle round.
Polly
GSB
Pull it out so that just the tip is in the hole, works for me...
I push mine all the way in (oooer   s:? :? s:?  ) and then push it to the top right of the hole (and again   s:? :? s:?    s:? :? s:?  ).
Comer
I turn the pump handle round until it's upside down and that works for me!
Michael
Now:  Black 2002 Rav4 Cruiser
GSB
Quote from: "phil4"I push mine all the way in (oooer   s:? :? s:?  ) and then push it to the top right of the hole (and again   s:? :? s:?    s:? :? s:?  ).
Oh dear...
Quote from: "GSB"
Oh dear...
sad isn't it,
next time just slide it in gently!!  s:lol: :lol: s:lol:
Sounds like this might be quite a common problem then.  Either that or you're all just filthy!   s:roll: :roll: s:roll:
Some interesting techniques to try ...not sure about just inserting the tip though, far too much potential for spillages!   s:wink: :wink: s:wink:
Polly
ahh, she's going to fit in well round here!!  s:twisted: :twisted: s:twisted:
I find it easiest to put it all the way in and then turn it anti-clockwise about 45 degrees...
(could be that our fillers are a bit different though)
well we did here you guys in Finland like being different Tem:shock:
Quote from: "Polly"Cheers
Polly
yep if it runs down your leg, don't light that ciggarette  :-) :-) :-)
Quote from: "kanujunkie"well we did here you guys in Finland like being different Tem:shock:
Nooo...it's the swedes...honest!  s:twisted: :twisted: s:twisted:
Quote from: "Comer"I turn the pump handle round until it's upside down and that works for me!
I did this once and mananged to spill petrol all over the forecourt!   s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:oops: :oops: s:oops:
Gaaaaa, tt was so embarassing!!!   s:cry: :cry: s:cry:
Sundance   s8) 8) s8)
Upside down or 11oclock and only a 1/4 in.  AND only half trigger!
I find different pumps in the same station can be completely different.
I always look forward to filling the focus, let the fuel flood into the tank
PS welcome to the club!
zud
I tend to ram it in, then pivot the base so that the tip of the shaft is pressed into the top of the tube... then i let rip at full tilt until it can't take any more.    s:wink: :wink: s:wink:
OK, enough Finbar Sanders!... put the pump in as far as it'll go, then push the handle down, so that the nozzle pivots on the bottom edge of the filler hole.  This makes the tip of the nozzle press into the top/back of the filler pipe... you can feel the pipe move slightly.  If you get it right you can fill up at full flow without any problem.
Blue SMT with leather, A/C and TTE Twin.
i agree with zud put the nozzle in and let the car take the weight of the pipe this normally works for me
if on the od ocasion this doesnt then i twist it quarter turn anti clockwise
I pull out slightly and also bend the handle to a slight angle. Bloody pain really  s:( :( s:(
Can't say I've ever had a problem getting it in and giving it a full load  s:wink: :wink: s:wink:
This has been discussed loads in the past - it depends on the type of pump that is being used. Simple rule is if you have trouble, go elsewhere!   s:D :D s:D
Never really had the problem and I use a number of stations. Just push it in, twist towards the back of the car about 45 degress and pump away..........
God, I feel like I am living in Viz!!!  s:roll: :roll: s:roll:    s:wink: :wink: s:wink:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
SimonC_Here
I have noticed that pumps on the same forecourt are different!
The shell station I use (yes, with optimax, no, no problems yet   s:) :) s:)  )
has one pump that just will not fill the tank properly no matter how I hold it.
Simon
Well, guess I'm not the only one!  Look forward to trying some of these suggested techniques.
Thanks for the warm welcome.
Polly
I have come across this problem quite a few times actually.  Always at the same petrol station (ESSO) and in a variety of cars, not just the MR2.
No problems whatsoever at my local Shell station.
so.simple
This is very annoying. See here (from the Jokes and Stories section) http://www.mr2roc.org/phpBB2/viewtopic.php?p=82450#82450
Carlos
 s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:   sorry , but thats excellent Carlos   s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
