lowered springs opinions wanted
Started by Anonymous, February 5, 2004, 20:25
i am thinking about getting the lowered springs from the main dealer
what do they feel like i.e are they a much harder ride
do they make the car look much better
basically should i bother to change
this posting should also go in the peformace section as well i suppose
great improvement all round. Do it.
though consider the eibachs they are cheaper.
MRMike
Evo had a long term car and loved them too..
"With less slack in the springs it changed direction in the esses like you'd replaced the front bodywork with carbon panels. On the road the ride was firmer and the MR2 felt better connected to the road surface, but it didn't seem any more crashy. In fact, the lowered suspension seemed to improve the previously jittery ride over awkwardly spaced bumps. The front end's extreme pointiness was also softened fractionally, a bonus on unfamiliar roads, although the steering did lose a bit of its delicacy".
I really need to get some sorted! It's just there is so many different things on my list!
Then.. Blue 350Z
NOW M3 V8
Liz
Plenty about lowering springs with pictures on:
 m http://www.mr2roc.org/viewtopic.php?t=1438 m
I'm going to get these done with my 1st year service. I assume the alignment will need checking afterwards  s:?: :?: s:?:
definateltm don't let them convince you otherwise it should be included as part of the fitting cost.
I'd have lowered ages ago if my 17's had been the right offset... anyone got any cheap adjustable struts going?  s:wink: :wink: s:wink:
told you should have bought my alloys  :-) :-) :-)
what happened to machining them?
Quote from: "markiii"what happened to machining them?
When I get my 15's to Telford, the one wheel that I scuffed in Paris is going in to be refurbed (again), they will look at machining it then - if they reckon they can do it, I'll have the other wheel done too, then hopefully I can buy me some Eibachs  s:D :D s:D
Comer
They are great mod.  The car looks like it should have came that way.  The cornering is better because you find yourself going quicker (as I now brake a little later!).
There is a little more feedback through the suspension but it's only a pain on very badly surfaced roads.
Michael
Now:  Black 2002 Rav4 Cruiser
I guess this has been talked about before and (sorry Liz) I don't really have time to trawl through the old posts about it, but what kinda price we looking at with fitting for the lowered springs? Not going to be an immediate buy, but if they are THAT good, then I might look to invest in 6 or so months........maybe along with the braces........  s:shock: :shock: s:shock:
I really must get to a meet and check the height of my car vs. everyone elses.. If I lowered mine any, I wouldn't be able to get to my house  s:eek: :eek: s:eek:  and there's only a 1.5" tall rumble strip thing outside the house! 2-up it already scrapes the bottom...
From what I remember Mr T quoted me about £350 to fit TTE springs.
But then they also tried to assure me that it wouldn't need the alignment checked afterwards!  s:? :? s:?
based upon the meet we did last eyar where we fitted 5 sets in a day,
it is unlikely that your alignment will move out of spec if you take care when installing teh springs.
HoweverMrT take care? unlikely
You are removing the struts to change the springs this means your camber settings at the very least will change. Whether they change enough to be outside specs who know, but they should at the very least do a check to make sure it still is in spec.
DO NOT accept NO for an answer. You shouldn't have to pay another £50-£90 to have this done afterwards.
Having said which fitting the springs is so easy I wouldn't pay them fo the privilige anyway.
Quote from: "Blanco"From what I remember Mr T quoted me about £350 to fit TTE springs.
  s:shock: :shock: s:shock:    s:shock: :shock: s:shock:    s:shock: :shock: s:shock:  how much!!, tooling won't cost much more than £30 provideing you have a socket set, hammer and pin punches, probably won't take any longer than 1hr per wheel plus a slow drive to get the alignment done  s:) :) s:)
GSB
Quote from: "kanujunkie"socket set, hammer and pin punches,
Dont forget the spring compressors!
Toyota fitted mine for £280 including geom check.
Car looks so much better now!
Quote from: "Jon H"Toyota fitted mine for £280 including geom check.
It looks like the dealers pick a price they think you'll pay as everyone seems to have coughed up different amounts again. Suppose its the local labour rates that does it  s:?: :?: s:?:
