oil leak
Started by Anonymous, February 26, 2004, 18:43
Hi all
Had my misty headlamp replaced under warranty today and when I went to the dealer to pick it up they said they had found a small problem that oil was leaking from the timing chain cover (not sure if I remembered the exact technical term right). Apparently its not leaking massively but enough that it should go in for a full days work to fix it.
The dealer said this was a known problem where the engines were not sealed sufficiently in the factory and the work required involves resealing this timing chain cover.
Any one heard of this or am I being blagged? - At least it is getting done under warranty and they offered a courtesy car.
Tom
Steve seems to think my car is doing this, but after cleaning the area where oil could be seen it doesn't seem to have done it since, and the oil level is as it should, but I will get it checked... at the end of the day you aren't being charged as it is pulled in under warranty so I shouldn't worry.
If anything it sounds like you have a service concious dealer!
mine did it slightly as did Steves first one, then stopped.
what oil are you using?
using the oil that the dealer uses during the 1st year service...
Mines the standard semi-synth too.
magnatec?
Quote from: "markiii"magnatec?
No idea, don't think so though.
in theory it's because the oil is too thin. magnatec is a main culprit for this when hot.
Hmmm, I'll check with my dealer.
Comer
Mark have you changed your mind about Magnatec being ok for the '2?
I've still got Magnatec in mine (2000 miles since oil change) but I'd like to know whether you've learned anything from having it in yours?
Michael
Now:  Black 2002 Rav4 Cruiser
SteveJ
Quote from: "Comer"
I had a report from someone who worked for TRL doing long term oil testing (in of all things an NA MkII), and all GTX oils (Magnatec included) go very thin after a few 1000 miles, which is why myself and mark have stopped using it.
scottee
What oil do you guys recommened cus out of curiosity.
My engine warning light came on suddenly one day and the eventual diagnosis was this exact problem. The engine had used oil all it's oil in about 100 miles. It required a new tensioner and seal.
Seems to be fairly common place and I've not had any trouoble since it was sorted.
dave
