16" wheels?
Started by Anonymous, March 4, 2004, 13:51
...I've searched but can't find what i'm looking for and also posted on SC.
 Are 7.0 X 16" ok on the MR2?
 With 205 on the front and 225 rear?
 Also does anyone know the weight of the stock wheels?
Shouldn't be a problem - AFAIK 16" all round is what TRD recommend for use with the Sportivio set up, which is also a bit lower than stock. 7" isn't that wide either, many people have put 17s on without too much hassle and I bet most them are wider than 7".
I'm thinking of changing my MR2 to a newer one and installing the Sportivo which is why I wanted to check.
I can get better, lighter and cheaper 16" than the TRD wheels.
mph
Quote from: "WoodenDummy"I'm thinking of changing my MR2 to a newer one and installing the Sportivo which is why I wanted to check.
Sanity check: the Sportivo isn't really suitable/necessary for an '03 - only need anti-roll bars and springs as the shocks have already been uprated.
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
Ah sorry no I was a little misleading, I've found a silver '02 with 10k on the clock with sat nav so I was thinking about changing.
How does your turbo do with 15"?  Ever feel like you'd like a little more traction?
mph
Quote from: "WoodenDummy"How does your turbo do with 15"?  Ever feel like you'd like a little more traction?
I'm currently on A539s which have very little traction in the scheme of things. If I wanted more, I'd simply switch to Yoko Advan Neovas (even though that'd mean 195/50 all round!) or if I wanted insane amounts of traction, I'd have A048s.
Remember, what you loose in traction, you (normally) gain in progressiveness.
Quote from: "WoodenDummy"Are 7.0 X 16" ok on the MR2?
TRD recommends this with Sportivo:
Recommended Tires:16-inch high-grip (Size: front 205/45R16, rear 215/45R16)
Recommended Wheels:1-piece aluminum alloy wheels (Size:16×7.0J Off Set + 45mm)
The stock wheels (pre facelift) are 14.6 and 15.2lbs.
The wheels i'm looking at are 13lbs.
What do you think?  To heavy?  When I put tires on it might add up, I don't wanna kill my acceleration
Quote from: "WoodenDummy"The wheels i'm looking at are 13lbs.
At 13lbs a piece they sound OK to me.. try my Mille Miglia wheels afterwards and see if you made the right decision!  s:lol: :lol: s:lol:
Compared to about 15lbs stocks...they are about 15% lighter. But you are moving the heaviest part of the wheel 1/2" further from the centre. I'd say it's pretty even with the stocks in the end...
How about Racing Hart CP-035R...? They would be only 10.8lbs in 16x7" and are still less than the TRD wheels  s;) ;) s;)
I really wanted a black or grey.  I'm having a hard time finding a grey/black 12lbs wheel in a 16"
hmm they don't do the 035R in 16 but they do the 035.  Still no black  s:( :( s:(
have ir refinished by seans man at KN Wheels
I must have missed this one, who, what, where, when, how much?   s:wink: :wink: s:wink:
Quote from: "WoodenDummy"I must have missed this one, who, what, where, when, how much?   s:wink: :wink: s:wink:
Wake up Ben!  s:wink: :wink: s:wink:
I use a guy at KN Wheels who refinish all types of wheel by acid stripping to bare metal, repairing any damage with aluminium, shot blasting then paint / laquer / bake.
The results are fantastic, I'm sure you saw my wheels at last years JAE...
must... open........ long............. term........ memory................. can't remember what........ I......... had............. for........ lunch!
How much does it set you back?
Unbelieveably, £25 a rim  s:shock: :shock: s:shock:
Quote from: "Slacey"Unbelieveably, £25 a rim  s:shock: :shock: s:shock:
You are kidding!  That is a bargin!  Your rims looked great.
Wow that makes things much easier, now I just have to find a wheel in the right size under 12lbs.
Did the paint last ok?
I know much, much cheaper that I have ever paid in the past  s:lol: :lol: s:lol:
I also know people that have paid much much more!
Seans word on the guy is good enough for me, £25 isn't enough to make me question if I want to look for cheaper  s:) :) s:)
oh also its  w www.knwheels.co.uk w  not .com.  s:) :) s:)
juansolo
Quote from: "mph"If I wanted more, I'd simply switch to Yoko Advan Neovas (even though that'd mean 195/50 all round!)
  s:twisted: :twisted: s:twisted:
That is going to be soooooo much fun.
what about:
Front: 195/40/16
Rear:  215/40/16
or
195/45/16
205/45/16 or 215/45/16
would the lower profile make that much difference?
Quote from: "WoodenDummy"Did the paint last ok?
Yep, the 17's have been done almost a year now and the finish is as good as the day they were done, even with all the salt and acid wheel cleaner I have used!
Will the standard 2003, 16 inch alloys off the rear, fit on the front??
Just a thought, be an easy way of having 16 all round..
Jon
