What's the correct torque for re-fitting 02 Sensors ?
Started by Anonymous, April 12, 2004, 14:33
Found this description on Spyderchat for a pre-cat inspection :-
"Remove heat shield bolts. First lift up shield, then unscrew each O2 sensor in turn, then remove heat shield. You can look down in with a flashlight. Retorque bolts properly."
My 02 Sensor is due to for delivery this week.
cheers,
Puggman
I have no idea, but find they turn quite easily, then tighten very wuickly, there is no gradual tightening as with normal bolts. I just hand tighten them, then do the last bit with the O2 tool, but it doesn't turn much.
Think it's strip the threads then back a turn   s:wink: :wink: s:wink:
Sam
The workshop manual gives them as 44Nm / 33lbf
Sam
[size=75]\'01 Black Roadster
Leda Adjustable Struts/Eibach Springs/TTE Stabilizer Bars/TRD Bracing/TTE 17" 9-Spokes/Toda Flywheel/Unichip/TTE Exhaust/TTE Front Bumper/TRD Quickshift[/size]
