tommyzoom99
#1000
Quote from: "Meeerrrk"Thanks Tommy. I haven't really had a chance to try it out yet because I'm being really careful while running it in. Out of interest what regime did you use for your tuned 1zz rebuilt engine?
I don't know what gear oil was used when the box was done so I'm changing that with the engine oil once I've done this magic 500 miles! Ordered the Redline MT90 from Opie oils again.
310 down (plus the miles Patick did)  s:D :D s:D  getting there
Hi Mark
We did in total about 1000 miles running it in
We did the first 500 miles on special running in oil (millers) then switch to redline 5/30 and still use that now
Started off for the first 250miles keeping below 3k but loading the engine using ¼ and ½ throttle on a/b roads not sitting on a motorways just gently driving it around
Then started to increase the revs to 4-4.5k still only ¼ - ½ throttle for the next 250miles
Once we had done this we swapped out the running in oil and continued to drive it around and slowly started to take the revs up to 5/6k occasionally, and using full throttle but only a few times for another 500miles and also did a bit of motor way driving but not much mainly b/a roads loading the engine on hills etc
As we got closer to the 1000miles we started taking it to the red line occasionally
Then after about 1500 mile we took it on the track and thrashed it and was fine never missed a beat since
hope this helps
cheers tommy
My track project
viewtopic.php?t=51237
Quote from: "tommyzoom99"
Hi Mark
hope this helps
cheers tommy
Brill thanks. Similar to what jaworjawor has said, which means I'm doing all the right things! I'll be swapping my oil soon  s:) :) s:)
JoeCool
#1002
I've had that lift off over-run grinding rattle on 2 cars - My Mk1 MR2 and an impreza. Both got absolutely thrashed, I did about 20K miles in the MR2 with that noise including 6 trackdays IIRC, and it didn't worsen and nothing failed. I put it down to 'character'.....
2ZZ '02 Roadster
Thanks, makes me feel a little better but I'd rather know what caused it. Did you ever get to the bottom of it?
JoeCool
#1004
Mine was a collapsed bearing in the diff.... Mechanically sympathetic I ain't. I sold the car with a £50 spare gearbox, and the next owner reported thst swapping it out and putting a new clutch on it cured it.
The secret is to care less. If it was perfect, it would be an insult to God.
2ZZ '02 Roadster
I suspect diff to be honest. I suspect something has happened when swapping it between boxes. FML!
Lee H
#1006
I'd suspect diff as well. Was it all reshimmed to suit the tolerances in the new box? I didn't do this with mine and it whined ever so slightly on the overrun so suspected it was down to that.
2000 black Roadster - hardtop, 16" Rota Grids with T1R\'s, TTE springs, TRD bodykit, JDL spoiler, 2.0 16v turbo swap with forged internals, Apexi AVCR, Apexi intake, ST205 chargecooler, JP custom exhaust, Accord Type R Recaro\'s
Sadlebag
#1007
I've always been told when you change the clutch to always use a Toyota release bearing!
Quote from: "Lee H"I'd suspect diff as well. Was it all reshimmed to suit the tolerances in the new box? I didn't do this with mine and it whined ever so slightly on the overrun so suspected it was down to that.
Who knows! From what I've been reading and what people have said, it sounds as if not....
I'm going to change the fluid in the box but I very much doubt that will help.
I'll have to get one of my fiends to look at it for me, he has a workshop near Uxbridge  s:( :( s:(
Escy
#1009
Quote from: "Meeerrrk"I'll have to get one of my fiends to look at it for me, he has a workshop near Uxbridge  s:( :( s:(
You should take it back to the person who fitted the LSD in the gearbox.
Quote from: "Escy"
Should yes, but It's just too much hassle for me to keep going all that way at great expense in both time and money to do so!
MrStev3
#1011
Let's hope this is the last issue for a while
Mitsuko the mr2
headcase
#1012
Yes the diff was reshimmed and preload done lsd come out of a secondhand box supplied was not tested got dropped of lsd taking out and put in box and 6th swapped at same time no new bearings or parts were fitted .
Quote from: "headcase"Yes the diff was reshimmed and preload done lsd come out of a secondhand box supplied was not tested got dropped of lsd taking out and put in box and 6th swapped at same time no new bearings or parts were fitted .
I thought you were on holiday? I'm surprised you didn't notice the noise when you did those 130miles.
Any way, as I read between the lines, it's down to me, and as said I can't keep bringing the car back and forward at great personal expense in both time and money.
Quote from: "MrStev3"Let's hope this is the last issue for a while
It seems unlikely doesn't it
cabbydave
#1015
Just drive it until it breaks enjoy it
In other news, I'm over 350miles now - I should be at the point that I can change the oil out but I'm going to cover the 500 miles myself to ensure its done the required mileage. With my luck, and all that!
Quote from: "cabbydave"Just drive it until it breaks enjoy it
I'm going to have to!
tomaky
#1018
Dont even talk about luck atm Mark im having a nightmare!
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
3 roadsters surely can't equal 3x the trouble
tomaky
#1020
Had a nightmare with the trailer guy lieing to us.
Still havent got 1 out of the 2 rear brake hoses im changing due to one rupturing!
I am driving to kent at the end of the week need it sorting.
Westfield Seiw
Ex - 2003 Sable
tomaky
#1021
The way its going i will be putting the sable on the road and leaving the blue one too sit in the garage ha.
Westfield Seiw
Ex - 2003 Sable
500 very careful miles done! Been enjoying driving the car for the sake of it, even with the horrible gearbox noise. And even though I can't Rev it yet.
So ready for an engine oil change, gearbox oil change change and start bringing the revs up, and , maybe, even bring it briefly into lift!
I've also 90% decided to join the Toyota sprint series in 2016 so I will need to get the car fully run in and tried and tested before March  s:) :) s:)
Leethesparky
#1024
The suspense is intense waiting for you to rack these miles up!!
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
