2zz oil cooler question
Started by TiM3, May 3, 2014, 08:56
TiM3
This is the oil filter assembly on the T Sport engine, I'm in the middle of putting in my 2, is the small oil cooler setup standard? Is it effective?
2001 MR2 Roadster - Cusco front strut brace, Chico Racing shift bushes, soft top delete, 2ZZ-GE, Eliseparts sump, 6 speed box, 4.529 final drive, LSD, custom induction, Zorstec 4-1 manifold, 100cel cat, P&P full cage, RRS 6 points, Cobra Imolas, BC Coilovers (5/7) BattleVersion rear arms, polybushed front arms, poly windows, gutted doors and dash.
Without knowing but the roadster has it as standard but instead of being a cooler its a heater
vinp182
Import roadsters don't have it
2001 Nissan Silvia S15 SpecR
1993 Rev4 Turbo mk2 300whp
1994 Rev3 Turbo mk2
2004 Renaultsport Clio182
SteveJ
Rich is correct - it's only fitted to colder climate cars (UK & Europe). Japan, US & Australian cars didn't have one.
Quote from: "vinp182"Import roadsters don't have it
But then it a spyder and not a roadster if it an import.
p3t3
I know on some guides it says to block the water rail and remove the oil cooler. I went with the 'if it ain't broke, don't fix it' approach and left mine on..
Makes it a little easier to grab the oil filter with it been a bit lower when it comes round to changing the oil  s:) :) s:)
Any landing you walk away from is a good one!
Vietts
I removed mine so i could install my rotrex bracket  s;) ;) s;)
cabbydave
Its up to you Tim either keep it on as it warms the oil up faster and keeps it cool as well. However if you take it off completely you can get a sandwich plate and put a separate oil cooler on the car.
TiM3
I think I'll keep it on, I can't afford an oil cooler since spending all my money on an Eliseparts baffled sump!!
