URGUENT: Where do i add water in the MR2 for the radiator
Started by Anonymous, August 30, 2004, 13:04
Im stumped, where do I add water to the MR2 roadster for the radiator to cool cheers.
This is urguent a sim about to go on a long drive.
Thanks peeps.
The radiator reservoir is onnthe far left side of the engine bay, largish clear bottle with (as standard) a pink coloured liqiud. The level should be between low and full when the engine is cold, it will be higher during operation.
Thanks for that, so its at the back then, can u not add water.???
Yes, provodong it is pure - tap water is OK for a quick fix when you are stuck, but otherwise I wouldn't. Most garages sell the pure stuff.
Ive had the car 18 months, i work from home and dont go may places. Ive never added water i dont think to it.
Looking into the engine bay to the left (my apexi intake you can see is where the stock airbox 'elbow' is...
As I said, the bottle with pink liquid is the reservoir.
OK just found it, its just below full and is pink. Ive never added anything and its still fullish, surely it should go down quite a bit in 18 months.
Not necesssarily - mine hasn't changed in two years. If the level is where you say it is, then it's fine.
Thanks for that, gonna go to manchester airport for a drive i think.
how geeky lol.
Quote from: "Brad123"OK just found it, its just below full and is pink. Ive never added anything and its still fullish, surely it should go down quite a bit in 18 months.
It's a sealed system so it should never go down at all.. If it does then you have a leak, which needs fixing  s;) ;) s;)
So yours sounds fine  s:) :) s:)
