SpyderLEE--Widebody gt300 turbo project
Started by Leethesparky, February 8, 2015, 18:22
andyroo104
#175
Great news Lee,maybe they have finally sorted the fitment issues,problem areas are normally a gap under the rear lights and gap between bumper/wings.
Leethesparky
#176
No gaps Andy,  the bumper and the side vents were made when I ordered, the side skirts and spoiler were off the shelf
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
andyroo104
#177
Good to hear that they have sorted the issues then,looking great anyway mate.
Ripley
#178
Would it help to line the diffuser with some of that heat proof matting?
Leethesparky
#179
Bumper is on.... not wet n dry'd yet leave it another day.. but my spraying is getting better, no runs, no orange peel.. turned out really well.
The jdl is slightly higher in the middle so can't get the diffuser on over the cat... but after the weekend there won't be a cat there, so it can go back on later.
andyroo104
#180
Love it,great work Lee.
Going well! Credit to you for trying your own painting
Leethesparky
#182
I've got some car porn!!
Wow!!
For god sake slow down.
Thats what the wife will be saying once you've that lot fitted.
Leethesparky
#185
Ok, it's in, it runs, and it's a lot faster than I thought ...
runs like crap though, got some stuff to sort, p0100 comes on and stays on after first full boost. It's running way too rich, won't idle properly. Runs like crap at a constant speed,
But used the hass 2 map off the reference and adjusted the injectors back to standard as the map had 440cc injectors.
Think I will leave it for now and order a wideband afr meter.
not going to buy anything else for a while now. Want to properly finish everything I have already.
Any advice on mapping is welcome and any thoughts on that maf light too
like I said it only comes on after the first full boost after leaving the battery disconnected.  I can drive at low revs without it coming on.  And it stays on. It won't reset with a obd reader.
men3cac
#186
Pay someone to map it. I did my kit car with a wideband on the road, but it's impossible to hold it at high loads and get it right as it fired off down the road (over 260 bhp/ton). I took it to Bailey Performance when I couldn't get any further- he made a real difference in the mid range, much more drivable after. And much faster!
men3cac
#187
Ps- impressive work though, you really don't hang about
Madness! Where did you get the kit from? Intercooled or charge cooled?
We need more pics!!
Leethesparky
#189
The laptop I was using for the ecu died.... lol
Had just put on a map which I knew would over fuel. And was just about to adjust it.
I had to drive home 10 mile using more fuel than a jumbo jet. Used quarter of a tank to get home. It did not matter how careful I was I could see the needle moving.
There is no intercooling yet, it's the basic whifbitz kit.
Oh ok, new stuff, not used? Was it easy to fit?
Leethesparky
#191
It was really easy to fit. Once a oil return was fitted into the sump, the rest of it just bolted on.
Took only a few hours to fit it all.
Getting it to run right will take me a lot longer
didn't really want to pay for a map yet until I fit intercooling , injectors etc.
Nice! Once again, great work  s:) :) s:)
s12vea
#193
You don't hang about! Get it mapped and it will drive nicely I bet.
Ex TTE Turbo
Another one won't hurt  .....
Leethesparky
#194
Ordered a new maf sensor today, can't get rid of that p0100 light. Must have damaged it swapping over.
feralcrew
#195
Really nice build, seems like somethin I would do with infinite funds  s:) :) s:)  How will you go about lowering it?
2000 Absolute Red MR2, Rotrex 1ZZ in the making. And I finally have myself a hardtop \":D\"
Build thread that\'s not really up-to date - http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=54484
Leethesparky
#196
Quote from: "feralcrew"Really nice build, seems like somethin I would do with infinite funds  s:) :) s:)  How will you go about lowering it?
It's already lowered with tein springs, 29mm on the front 30mm on the rear I think.
Hopefully maf sensor and afr meter should be here today so I can have a proper look.
Leethesparky
#197
Maf is in, took out the boost controller to keep it a low boost about 5 psi for safety. added the c2 map to my emanage. Added a timing map to it, changed a few settings to better match my setup.
Car is running perfect. And quick!!!
Afr gauge will be here tomorrow so see if I can take it back up to 7-8 psi when I can properly see what's going on. If it's pushing the injectors too much I will drop it back to what it is today, as I'm happy with it. It is sooooo much faster than the standard car.  :-) :-) :-)
7-8 is very likely more than a stock can do, I max the stock injector at 190 but that was NA
Great stuff! Amazing what you've achieved.
What's next?
