Using pre facelift rear wheels instead of facelift fronts
Started by js1mr2, August 30, 2015, 17:18
js1mr2
Has anyone tried using the pre-facelift rear wheels (205/50/15) on the front of a facelift MR2 instead of the stock fronts (185/55/15)?
With the wider 215s at the rear and LSD I've found that my facelift MR2 has a nice balance on the road but understeers when pushed on the track, particularly if the tarmac is damp or greasy, despite experimenting with front camber and ride height. I can't afford a separate set of track tyres and wheels but thought a solution may be some slightly wider front wheels and tyres and liked the idea having front wheels that matched the look of the rears. Has anyone tried this before or has any thoughts?
Cheers Jeremy
MilesH
Yes and does exactly as you hope. It gives you slightly better grip on the front.
Not sure on your current geo but if you add a bit of toe out on the front as well (1mm overall should do it) it should give you a good turn.
doodlepugg
This is something I'd like to play with, being that I've only ever had FR's I like a sharp turn it and balanced slightly toward oversteer. I guess with the MR2 you have to be careful not to induce the dreaded snap oversteer, though. These cars do have a LOT of rear end traction.
I fitted wider front tyres and the understeer totally disappeared, it's a lovely balance even when pushed hard.
The only problem I've found is on track in the wet, no rear grip at all!
Yep did exactly that with no issues
js1mr2
Quote from: "Meeerrrk"I fitted wider front tyres and the understeer totally disappeared, it's a lovely balance even when pushed hard.
I was expecting to experience the same after watching your vids of Brands when I went there in January but just had lots of frustrating understeer in slow and medium speed corners. What size wheels and tyres are you running?
I'm running 225/45/16 rear and 205/45/16 fronts to keep the stagger, it worked for me.
js1mr2
I'm planning to fit my 205/50/15 PFL rear wheels on the front of my mr2 this weekend, is it safe to use the standard front wheel nuts or do I need to buy 'rear' PFL wheel nuts does anyone know?
CrazySX
Quote from: "js1mr2"I'm planning to fit my 205/50/15 PFL rear wheels on the front of my mr2 this weekend, is it safe to use the standard front wheel nuts or do I need to buy 'rear' PFL wheel nuts does anyone know?
Don't see the wheel nuts being an issue. They are the same.
js1mr2
I though the PFL rear wheel nuts are different to the front wheel nuts?
TiM3
Yes mine are different too, rears are a bit longer. Without checking it might be because the rear studs are a little longer hence the nuts need more thread to accommodate.
I'd just trial fit a wheel with the front nuts and as long as they are tightening the wheel up before the stud bottoms out in the nut then you should be fine.
2001 MR2 Roadster - Cusco front strut brace, Chico Racing shift bushes, soft top delete, 2ZZ-GE, Eliseparts sump, 6 speed box, 4.529 final drive, LSD, custom induction, Zorstec 4-1 manifold, 100cel cat, P&P full cage, RRS 6 points, Cobra Imolas, BC Coilovers (5/7) BattleVersion rear arms, polybushed front arms, poly windows, gutted doors and dash.
