Tyre wear...
Started by Anonymous, December 10, 2004, 13:26
I'd noticed recently that the rear end of my '2 had been a bit twitchy - and has even stepped out a bit when turning - under normal driving (in hindsight seems to mainly be when turning right) and even when accelerating hard in a straight line.
I know the roads are pretty greasy - but thought this was odd - as I didn't remember my AW11 being like that.
So I checked the tyre pressures and they were all fine.
Then I noticed that the left rear tyre looked like it was just legal on tread   s:oops: :oops: s:oops:
However the right rear tyre has about 3mm left on it!
So is this normal? The wear on the left is even across the tyre; I took the car to our local tyre fitters and he felt that if this was due to poor alignment then the wear would be uneven...
I initially planned to get just 2 new rear tyres (Toyo Proxes T1-R's) but of course the Tyres on the '2 at the mo are Continental Sport Contacts - and as I don't want to mix tyres I'll have to have 4 new ones!
So my questions are;
Will the difference in tread (combined with the pants road conditions) be causing the odd twitchiness from the back?
Is this uneven tyre wear abnormal? I suppose "spirited driving" around roundabouts would cause the left rear to wear quicker...  s:wink: :wink: s:wink:
I've been quoted £230 for a full set of T1-R's fitted - is this a good price?
My current front tyre's look almost new - so what do I do with them?
Try and sell them on ebay? If so; how much should I ask?
Questions, questions! Thanks in advance for any help   s:D :D s:D
do uk mr2s have lsd's??
i have had the same problem repeatedly, but in my case it was the result of autocrossing and the open diff.......
i would put the contis up for sale here or on ebay, you never know who'll need just a pair of tires.....of course, you could just buy two new contis for the rear, unless you're not happy with them..........
kev
Quote from: "kulprit"do uk mr2s have lsd's??
Yep...
Well I've got a full set T1-R's on now - what a difference!!!
The roads are SOOO greasy I wouldn't even consider pushing it, but the car feels completely transformed; a lot pointier and with a lot more feel...
and they only ended up costing £210 fitted - not bad   s8) 8) s8)
I think I may have discovered the cause of the un-equal wear between the right and left tyres; the tyre fitters noticed that the right rear alloy is the standard 6.5 inches wide, but for some reason the left is only 6 inches wide!!!   s:oops: :oops: s:oops:   s:shock: :shock: s:shock:   (the fronts are both the correct size, btw!)
I rang the previous owner (who owned the car from new) and he was adamant that he hadn't had any of the alloys changed.
So I went to my local Mr T (it's still under warranty) and they had no record on their central database that the alloys had been changed under warranty...
However, 3 of them need replacing, one front and both rears, due to corrosion (I want all 4 replaced - we'll see...) so they said they'd put it to Mr T whether they can replace them under warranty.
So fingers crossed that this will get sorted...
After I'd fitted my member braces I noticed that the rear of the car had got a little squirmier if one of the rear wheels went into a pot whole / over a drain cover - I thought this was because the rear was more rigid; however it's probably also because one of the rear tyres sidewalls could flex more as it was on a narrower alloy and this was more noticable due to the chassis bracing!   s:shock: :shock: s:shock:
On a plus side my best mate has just bought a T-reg Ford Focus that needs new front tyres - which happen to be 185/55/15's - so my tyres are now sold!   s:D :D s:D
Quote from: "Mr 2"and they only ended up costing £210 fitted - not bad   s8) 8) s8)
  s:shock: :shock: s:shock:  good God! that's cheap,  i paid £224 for the 2 rears and they were potenza's:shock:
Quote from: "kanujunkie"
I know - that was for a whole set of T1R's fitted (185/55/15 fronts and 205/50/15 rears)!!!
I would highly recommend them (Tyres (King's Lynn); 01553 773265 - if anyone's interested) - they fitted my TTE exhaust (they do exhausts too!) for £35 - took them a couple of hours and they made a really good job of it too!
I think it helps that I've bought 2 sets of alloys and at least half a dozen sets of tyres from them in the past   s:wink: :wink: s:wink:
But they always have the cheapest prices that I've found...
... now just to get the alloys sorted!!!
Bongo
Quote from: "Mr 2"Well I've got a full set T1-R's on now - what a difference!!!
I noticed the opposite - car seems to have a whole lot less pointiness and feel now... I'm waiting for the release agent to be scrubbed off before i make any judgments though.
The fact the tyres are lighter has given me a noticeable increase in acceleration though   s:D :D s:D
Quote from: "Bongo"
I think it feels better for me because the sidewalls on the Continentals' that were on previously were super soft and added a bit of a fudge factor to the handling. The T1-R's have a noticably firmer sidewall (ride is a little harsher - but in a good way; feeling the road through my bum more!   s:oops: :oops: s:oops:  )
There is a bit of slide-iness (like the technical terminology   s:wink: :wink: s:wink:  ) but I think this is because the tyres are new - i.e. got releasing agent on them, etc...
