2ZZ Compressor
Started by KRAMSNEHPETS, June 26, 2016, 22:38
KRAMSNEHPETS
Looking forward to Headcase fitting the Corolla Compressor kit I collected yesterday  in August!
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
inside
Nice! Where did you get the kit? What ECU will you run?
KRAMSNEHPETS
Got it all from Sam nadeem, came with the standard ECU and a Det 3
MR TWO
Should be awesome. I look forward to hearing all about it!
inside
How much £££?
I think you won't be able to run it on standard corolla ECU because it won't run dashboard (unless you keep the stock ecu for running dashboard)...
KRAMSNEHPETS
Headcase is fitting it all for me. He has the knowledge! .
mikek
Should be great. Was going to have that for mine but ran out of cash. Will be reading this with interest as it's something I would like to do in the future.
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
cabbydave
You do know how much this is going to cost me now. I have a rotrex and all the bits, I have a 2zz  but cannot decide which car to drop it in. The worse bit is now the strong Dollar as I was going to buy a Apexi looks like I will have to run the Greddy ive got instead.
You can drop it in mine if you want...
cabbydave
I wish I had time out of the house for 14 hours of the day and half the day saturdays. Then my time off kids always want something. Money is nice but when do I spend it? On the plus side I bought the car the 2zz is going in last night 2000 import in blue nice straight car just needs a engine
KRAMSNEHPETS
get it done!
You are costing me a lot of dough!
oxbowbutterfly
Hi
Having owned a compressor for six months, I have to say you are in for a real treat. The engine is sublime and so much low down torque, after the first few months, I only used lift when it was up against something special or couldn't resist showing off on the motorway. I sold it to a friend with dibs on it when he sells. I plan to Rotrex mine this winter if I don't hear from him by Sept. Seriously, one of the nicest engines I have ever used. Just a shame they put it in the Corolla!
Black MR2 with red hood and black hard top. Mtec drilled and grooved discs with Green stuff pads all round. 2ZZ engine with PPE header and sports cat and stock back box.  6 speed Corolla box! Tein lowering springs.
cabbydave
Quote from: "oxbowbutterfly"Hi
Isn't it great driving at 3000 rpm and it still pulls like a train even in top
inside
@cabbydave, so you're on compressor too? Anyone else here running stock compressor on 2zz?
It would be really good to document some of this stuff, especially the ecu being used. AFAIK the corolla ecu can be used for engine, but not for the dash. If there is a elegant way around this, it would probably be much more compelling addition to 2zz  s:) :) s:)
KRAMSNEHPETS
Delivered car to Patrick on Sat. Due to pick up 26th August. TTE Compressor, intercooler, DET 3 ECU, new shocks, radiator and correct ratio 5th gear all being done!. Tuner setting it up on rolling road on 25th
Looking forward to getting it back.
Any good insurance companys I should speak to about the mods?
Flux has been cheapest for me since going turbo.
KRAMSNEHPETS
Get the car back end of next week, cant wait!
Look forward to hearing about your first drive:-)
Where is Patrick based?
KRAMSNEHPETS
South coast, Bexhill On Sea
Thanks!  - ok that's a couple of hours drive for me.
I am up your way on bank holiday monday not in my 2 unfortunately.
Not been in a 2zz supercharged.
KRAMSNEHPETS
Your welcome to pop by if you want me to take you up the road in it,
Quote from: "KRAMSNEHPETS"Your welcome to pop by if you want me to take you up the road in it,
Would love to but perhaps a time when i am under less pressure to do DIY at mother in laws.
I will bring the turbo up sometime and we can do a back  to back comparrisson.
Ooooohhhhh you're 45 mins from my work.... Could I arrange an evening  in a couple of weeks to come past your place and check it out??
Blue al
 s:D :D s:D  Shame only one passenger seat
I think you could sell tickets
