Scotts Yellow Supercharged V6 Roadster
Started by 1979scotte, March 22, 2017, 07:27
Sound great.
Lots of pops and burbles.
Sounds the muts nuts at 6k rpm.
Quote from: "1979scotte"Lots of pops and burbles.
And how about Bee6?
 s;-) ;-) s;-)
andyroo104
#152
Looking good, glad you got it all sorted.
Sent from my SM-T810 using Tapatalk
Am starting to learn that 1st is irrelevant and 2nd and 4th will suit most of the time.
Id imagine you'll have to change that statement when she is upgraded. I have a feeling there will be more gearing irrelevancy.
Good to see you getting some payback though.   :-) :-) :-)
Quote from: "StuC"Id imagine you'll have to change that statement when she is upgraded. I have a feeling there will be more gearing irrelevancy.
This is a good point.
May aswell just be 3 speed. 2nd 5th and reverse.
You could be onto something there!  s;-) ;-) s;-)
JoeCool
#157
Quote from: "1979scotte"Sounds the muts nuts at 6k rpm.
6k? Is that all it goes to? How do you accelerate?   s:crazyeyes: :crazyeyes: s:crazyeyes:
2ZZ '02 Roadster
Quote from: "JoeCool"
It goes past 6k just about. Makes maxpower around 5400 rpm.
It accelerates due to torque something that you and your 2zz will never understand.
JoeCool
#159
I have torque too. I just use a gearbox to generate it at the wheels, not a taxi cab engine. :p
2ZZ '02 Roadster
Quote from: "JoeCool"I have torque too. I just use a gearbox to generate it at the wheels, not a taxi cab engine. :p
Torque  s:lol: :lol: s:lol:  like 130lbs mine makes over 200 and i havent even started working on it yet.
JoeCool
#161
You and I need a hot date on an Essex airfield my friend.
2ZZ '02 Roadster
MilesH
#162
What are your plans for it?
Quote from: "JoeCool"You and I need a hot date on an Essex airfield my friend.
You only beat me last time because of tyres.
Youre going down like Klitchko.
Quote from: "MilesH"
My heart says supercharger more than likely a rotrex.
My head says stay nice and reliable with na.
If i could get a 3.3 block from america or japan that would be nice too.
KRAMSNEHPETS
#165
Headcase just had one arrive from USA!
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
Quote from: "KRAMSNEHPETS"Headcase just had one arrive from USA!
No he had a 3.5 2gr arrive i am talking about getting a block from a 3mz and mating it up to 1mz heads.
Saw your new engine looked good.
How much will that change the engine installation? Bespoke engine mounts required or is it interchangeable? Just thinking about that newly chopped rear subby not needing anything else out of it.
Quote from: "StuC"How much will that change the engine installation? Bespoke engine mounts required or is it interchangeable? Just thinking about that newly chopped rear subby not needing anything else out of it.
I believe externally they are the same. Its probably cheaper and easier to supercharge tbh.
Not both then?   s;-) ;-) s;-)
Quote from: "StuC"Not both then?   s;-) ;-) s;-)
Certainley.
If your paying.
btw dont you reply to text messages anymore  s;) ;) s;)
If I had it spare fella, not a problem!   s;-) ;-) s;-)
Are you sure about that last statement?   s;-) ;-) s;-)
Quote from: "StuC"Are you sure about that last statement?   s;-) ;-) s;-)
Beat you to it by a minute.
You'll be glad of these posts when you are reading through later on in the year.  s:-D :-D s:-D
What's the timetable for the changes?
Quote from: "StuC"You'll be glad of these posts when you are reading through later on in the year.  s:-D :-D s:-D
Car will be taken off the road in Jan so its all sorted for new insurance year in Feb.
If funds are availble.
