Scotts Yellow Supercharged V6 Roadster
Started by 1979scotte, March 22, 2017, 07:27
Mikeymead
#200
Quote from: "Call the midlife!"Before I get all giddy and express an interest, what brace are we actually talking about? Bearing in mind I'm PFL.. cheers.
If you look at Scotte's photo you will see two metal bars running from near the front of the car back towards the centre brace, they are just inside of the suspension mounts. On the FL they added two horizontal bars the join the two existing longitudinal ones.
Aaah, I'll not get giddy then but thanks for the explanation! [emoji2]
Just topped up the V6.
26 mpg.
Only 216 miles covered and 90 of those were on the m25/11.
Worst turbo mpg was 27 even on the Highland drive i was getting 30mpg.
but she makes a lurvely noise.  s8) 8) s8)
Did you buy a V6 for economy?  s;-) ;-) s;-)
Quote from: "StuC"but she makes a lurvely noise.  s8) 8) s8)
No but imagine how bad mpg would be with a supercharger and supra injectors.  s:( :( s:(
supplementary front tank to help with the weight ratio FR:RR ?  s;-) ;-) s;-)
Essex2Visuvesi
Quote from: "Essex2Visuvesi"A few more accents to go with your black car?
https://www.amazon.co.uk/dp/B0107ZV7TK/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2N28QJIK24PBA&coliid=IGVO0GJES2ZO2&th=1
Think 80 quid is a bit steep.
Quote from: "1979scotte"
£90, you missed off the p&p.
I've been looking at those sets to brighten up the dash but there's no red option...
vinp182
#209
Might be worth getting it on a dyno to see what the AFR is
I'd be getting a decent FPR if it hasn't already got one and I'd replace the fuel pump
Might see half decent mpg then
2001 Nissan Silvia S15 SpecR
1993 Rev4 Turbo mk2 300whp
1994 Rev3 Turbo mk2
2004 Renaultsport Clio182
Quote from: "vinp182"Might be worth getting it on a dyno to see what the AFR is
She does smell rich but the car is new to me.
Want her on a dyno anyway.
Thanks for the advice.
Tomos did question the mapping at the sale.
Did he give you both ecu's?
If so, now the throttle body is cleaned, is it worth trying the other ECU?
Quote from: "StuC"Tomos did question the mapping at the sale.
Anything is worth a try but i think its a long shot.
I am doubtful it will be any different.
Nothing to lose springs to mind.  :-) :-) :-)
Will it still diagnose in the same way? i.e. OBD2
Just wondering if it would throw up an error and still give you a light.
Steve from D1Customs may bring his diagnostic machine to Ding Day like last year so may be able to check it over for you?
24 MPG   s:( :( s:(
Cant be right can it?
dunno... Our Jag does 24 on a good day  s:) :) s:)
Quote from: "shnazzle"dunno... Our Jag does 24 on a good day  s:) :) s:)
Your jag must weigh 1500kg even with the V6 the MR2  cant be more than 1100
Depends what style of driving you have been doing but when both my afr sensors failed I was getting at worst 20 and you could smell the unburnt fuel behind me.
I wouldnt expect to drop below 28 now though but dont normally bother working it out so that is a bit of a guess. My fuel light came on at about 260  on the last tank.
I think closer to 2 ton, but yes 24 does seem a bit on the low side. Surely it can only be a case of o2/afr sensors or poor maintenance? It's not poor maintenance.. So surely there must be a mechanical/electrical issue somewhere?
Could be 02 sensors.
I cant make my obd2 scanner work perhaps it doesnt with the V6 swap.
Quote from: "1979scotte"Could be 02 sensors.
Perhaps it's the midi-chlorians causing a disturbance?
Please do not make reference to the truly awful episodes 1-3
Haha! You're not wrong! I was in the same room while the most recent one was one a while back and that didn't seem too clever either...
Surely midi-chlorians still play a role in the other episodes  s:) :) s:)
How else is the strength of the Force in someone determined?
