Scotts Yellow Supercharged V6 Roadster
Started by 1979scotte, March 22, 2017, 07:27
Quote from: "shnazzle"Surely midi-chlorians still play a role in the other episodes  s:) :) s:)
How else is the strength of the Force in someone determined?
Nah, it was all just suspension of disbelief until they came out with the reasons behind it, didn't need to know the hows and the whys just that Princess Leia was a fox...
Essex2Visuvesi
#226
Spaceballs was far superior
Haha. I love that movie! What ever happened to Rick Moranis?
Quote from: "shnazzle"Haha. I love that movie! What ever happened to Rick Moranis?
He got swallowed up by the merchandise!
Essex2Visuvesi
#229
Quote from: "Call the midlife!"
His wife died and he gave up acting to look after his kids
There were rumours of a SB2.  Apparently Mel Brooks would only do it if he could get Rick to come out of retirement
Quote from: "Essex2Visuvesi"
He's released a few "country" albums as well and done some voice work for animated films, he's one of those actors you don't realise how many films you've seen with them in until you sit and think about it.
Ooooh, what are the spring rates?
Quote from: "Topdownman"
Ouch! Well done...
Will you lot f off and spam someone elses thread.
LOL! Nice Simon. You win.
Sorry Scotty  s:( :( s:(
Back to yellow mr2s.
How does the v6 get its engine management sorted anyway? Is it running the stock ECU in tandem?
Quote from: "1979scotte"Will you lot f off and spam someone elses thread.
Yeah, sorry, I was forgetting where I was...
Quote from: "Call the midlife!"Nah, it was all just suspension of disbelief
Not 100% it certainley has 1mz ecu running the engine not sure if there is a 1zz running the clocks.
Small update.
Averaged 31mpg on the motorway to ding day and back happy with that.
Have a small fluid leak from somewhere. its dripping from the gearbox bell housing but after sending a few pics to headcase he reckons it could be the rocker cover gaskets and its dripping all the way down.
Fitted FL rear lights at ding day have the fronts to do next.
Also have camber bolts, roll centre adjusters and adjustable rear droplinks to fit. Wont do those until next year probably and then go to WIM for a setup.
Did you need the basket books as you have meister coilovers
Quote from: "StuC"Did you need the basket books as you have meister coilovers
You will have to explain that one.
I thought you could adjust the camber with the meister coilover set up, is that not the case?
Quote from: "StuC"I thought you could adjust the camber with the meister coilover set up, is that not the case?
Front yes rear no
lgriffiths
#242
Nice, the yellow edging is a bit bold, at least its not the whole car  :-) :-) :-)
JoeCool
#243
Quote from: "1979scotte"Fitted FL rear lights at ding day have the fronts to do next.
You need to help me out with the wiring mate. My car is daytime only since I fitted my front FL light,s they don't work proper!!!
2ZZ '02 Roadster
Quote from: "JoeCool"
John gave me some wiring adapters so i hope it will be ok.
Headcase will help me sort it he did his wifes with no problem.
Where'd you get the roll centre adjusters?
manos3003
#246
Front yes rear no
Seconded. You need camber bolts for the rear ones. I swapped them prior to alignment right after I fitted the MeisterR's
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
Quote from: "shnazzle"Where'd you get the roll centre adjusters?
GT4 play.
Stupink thinks they make a big difference.
Worth a try.
Oil leak sorted. Cam sensor needed sealant.
Earthed the temperature sensor back to the ECU so that should stop playing silly buggers.
Raised the ride height by 10mm.
Sorted the squeaky breaks.
Need new off side rear caliper handbrake won't behave.
Thinking about the rotrex.
May run it without an ECU up to 5 PSI.
We shall see.
s12vea
#249
Have you found a Rotrex?
Ex TTE Turbo
Another one won't hurt  .....
