Quote from: Ardent on August  2, 2018, 22:39
I redact my last statement.
Partially.
He did load it up with mr2 goodness for others at DD.
Did not pay attention to the what. Thought it was a skoda octavia estate.
Hahahaha!
Burn!
tricky1138
Quote from: shnazzle on August  2, 2018, 23:33
Partially.
Hahahaha!
Burn!
They're basically the same car anyway! haha
Hope it all gets sorted soon Scotte.
And here's me thinking how good it was to have a local expert to fit a V6 in mine when I decide to do it!  :withstupid:
Quote from: tricky1138 on August  3, 2018, 08:48
Partially.
Hahahaha!
Burn!
hmmmm....  I shall have to rethink my "support car" efforts clearly.. not too sure what kind of Audi is acceptable to you lot (if any even exists!)  - but in my defence it was going cheap!
Look at these gaskets.
No expense spared here.
Why bother with multi layer steel Toyota OEM gaskets when these are so good.
That settles it.
Cylinders 2 and 3 leaking.
These gaskets just didn't like the boost.
mikek
Any other damage or just new decent head gasket required?
New little car to follow soon
Quote from: mikek on August  3, 2018, 14:24
Looks good so far.
It will be having standard rebuild whatever.
Hopefully not serious bottom end work required.
mikek
I was expecting one side of the gasket to say "Kellogs"......
Sounds like the best news in the circumstances?
Quote from: Topdownman on August  3, 2018, 14:51
I am happy that we now know what the problem is rather than guessing.
It's proof that you can pass a sniffer test but still have a blown headgasket.
It probably only really let's go under boost or when it gets hot.
Kellogg's?
Probably been just as good.
I was under the impression that all the V6 swaps had MLS gaskets but maybe I am wrong.
tomaky
Anyone got the post code for woodsport? For the sat nav? POS's
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Talk with Patrick about head bolts/studs.. might need a bit better for the boost?
As I thought, lifting when the chamber pressure goes up.
Quote from: Carolyn on August  3, 2018, 15:57
ARP head studs.
Not 1mz specific adapted from another application.
jonbill
#763
To be fair, at least 50% of the results to my search just now for 1mz returned fibre head gaskets. I don't think you can't hang an engine builder for using a fibre gasket on an NA engine.
Quote from: jonbill on August  3, 2018, 17:00
To be fair, at least 50% of the results to my search just now for 1mz returned fibre head gaskets. I don't think you can hang an engine builder for using a fibre gasket on an NA engine.
but for a string of bodged engines..... you CAN draw a conclusion.
I wouldn't disagree and I am yet to see this gasket but someone who has seen hundreds of head gaskets has assured me this one is of very poor quality.
The picture below is what is going back on the motor.
A genuine OEM Toyota MLS headgasket.
s12vea
At least you have found what the original problem was before it was too late. Now you can make everything 100% before putting everything back together
Ex TTE Turbo
Another one won't hurt  .....
headcase
That's the part number of the MLS the gasket that is in it is what a aftermarket one looks like so a aftermarket headset is cheaper then Toyota one but don't use the head gaskets and replace with MLS one  because all the other gaskets in set are metal
Sent from my Pixel using Tapatalk
I would like to think a corner has been turned.
After lots of humming and harring.
Watching YouTube videos about cheap wastegates has caused me to blow the dust off me wallet and get one of these
And while it was out I thought I may as well get one of these too
s12vea
Ex TTE Turbo
KRAMSNEHPETS
saw your car on sat scott, popped down to discuss with Patrick the spec for my next engine
@1979scotte, as I mentioned previously when speaking with @dan944 and his mentioning of the kit on his 2, he explained the smoothing effect of the waste gate and how noticeable it was to the driver.
Would I be correct in thinking that the wastegate and /or BOV have this smoothing effect also on the engine? Equal and opposite reaction and all that.
So, could it be that these valves were not on Bee6 or where not operating at their optimum?
This being the case perhaps that is the root cause of your problem, the (I'll  call it )knock effect, at times found the weakest point of your engine.
@Joesson
The headgasket was going to give way with any form of forced induction they're were pony.
