Boot lid
Started by Garfy, March 31, 2017, 08:04
Garfy
Good morning folk, anyone know another way of opening the boot ? My lever doesn't seem to work   s:( :( s:(
Turned up at work this morning and have water running out of radiator   s:oops: :oops: s:oops:
I got 15 miles to get it home/garage if I take it easy would the engine be ok?
  s:bounce: :bounce: s:bounce:
Water cooled T25 turbo
Air to air intercooler
440cc injectors
ECU and electronic boost control
2.5" sports exhaust with twin tail pipes
brettfield999
Ud probably need to get under the front of the car and press the release.  Is it overheating?
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
Garfy
Strange it didn't show as running hot :-/
Erred on the cautious side, booked into a garage and green flag recovering once I've finished work.
Bugger, got to out the kia back on the road
440cc injectors
brettfield999
Is there a colour to the fluid and is your car an AC model.  Could it be leaking from the condenser?
Also check the rad bottle in the engine bay (left side)
Garfy
Couldn't see any colour to the fluid, cant get to see the rad bottle as can't get the boot open.  :-) :-) :-)
No A/C
Not nice to see my car on the back of a low loader  s:-( :-( s:-(
440cc injectors
brettfield999
Do you mean the front or rear "boot". I meant check the expansion tank in the back, my mistake
If you mean the engine lid (at the rear - opened via lever next to driver seat) as apposed to the frunk (at the front - opened via lever in glove box) I certainly don't have a boot  s:) :) s:)   then try following this: http://www.mr2roc.org/phpBB3/viewtopic.php?f=11&t=44534&p=521738#p521741. You will need a 2nd person to open it after you pull the lever the first time (or jam something to keep the lever up), then just twist the two rubber stoppers anti-clockwise.
Garfy
Thanks for the info, I always thought as the engine in the boot  :-) :-) :-) .
I'm on the  spiss piss spiss  in Derby now.
Car is in the garage in Hertfordshire, put my kia back on the road  s:-( :-( s:-(
440cc injectors
No problem. Hope it gets sorted in the garage. It's a boot on most cars, as long as you remember not to put your shopping in there you can think of it as whatever you like  s:D :D s:D
ianfcliffen
If you have a look through the plastic mesh trim you can see the cable, bend a coat hanger, slip through and pull. Worked for me. Then adjust the stop next to the catch to retension.
Sent from my SM-T550 using Tapatalk
