Auxiliary bypass filter
Started by m1tch, June 6, 2017, 12:42
m1tch
Hi all,
Just wondering if its worth looking into this at all, I know you can get dry sump systems for the 1zz which have their own much larger separate filter, however I was thinking about fitting an auxiliary bypass oil filter onto the stock engine using a sandwich plate. This would not only increase the filtering on the stock engine but also increase the oil capacity a bit as well, its amazing it only takes about 4 litres of oil.
Just wondering if anyone had done this at all?
