2ZZ Rotrex soon!
Started by KRAMSNEHPETS, June 14, 2017, 23:26
KRAMSNEHPETS
#50
[attachment=0:c5sfzq4g] ia0 20170710_201152.jpg ia0 [/attachment:c5sfzq4g]
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
KRAMSNEHPETS
#51
[attachment=0:1uyncguz] ia0 20170710_201417.jpg ia0 [/attachment:1uyncguz]
KRAMSNEHPETS
#52
[attachment=0:1q69jgp7] ia0 20170710_201249.jpg ia0 [/attachment:1q69jgp7]
KRAMSNEHPETS
#53
[attachment=0:126e586j] ia0 20170710_201226_001.jpg ia0 [/attachment:126e586j]
KRAMSNEHPETS
#54
[attachment=0:2g55jidr] ia0 20170710_201334.jpg ia0 [/attachment:2g55jidr]
jonty
#55
You're going to surprise a lot of people with that stock looking MR2 with a few TTE trim parts  s:lol: :lol: s:lol:  looks like a well thought out install  s:) :) s:)
As we are postings pictures do we have a Dyno printout?
Are you running a wastegate or bov setup how many psi.
KRAMSNEHPETS
#57
[attachment=0:3jehozmu] ia0 dyno.jpg ia0 [/attachment:3jehozmu]
jonbill
#58
Very nice. I don't understand the lambda line - seems to be saying lambda goes from 0.3 to 0.6 which doesn't make sense. How should I read that?
KRAMSNEHPETS
#59
I have no idea!
Rotrex make for a lovely looking plot on the graph.
Really can't wait for mine.
KRAMSNEHPETS
#61
You do not feel that its that quick at first because of the way it builds up the power, not a "turbo"rush, very linear. 40-60MPH 3 seconds. Going to take it to Santa Pod 19th August so that I can really open it up and get some solid numbers of what it can do
KRAMSNEHPETS
#62
What are your V6 standard numbers for torque and bhp?
OEM spec is 194bhp and 209 ft-lb.
I will get it on a Dyno at some stage.
I know it doesn't feel as good as Headcases rebuilt MK2 1MZ.
jonty
#64
Quote from: "KRAMSNEHPETS"You do not feel that its that quick at first because of the way it builds up the power, not a "turbo"rush, very linear. 40-60MPH 3 seconds. Going to take it to Santa Pod 19th August so that I can really open it up and get some solid numbers of what it can do
I drove a Ferrari F430 previously and it didn't feel that quick (in the context of my expectation that it would tear my face off) as that had very linear delivery as well.. But it will make it an absolute weapon on a track or when driven hard - you'll be able to get on the throttle so confidently I imagine! Just done the sums and your car will have a slightly better power to weight than the F430, nice!
KRAMSNEHPETS
#65
[attachment=0:2y36os4m] ia0 racelogic.jpg ia0 [/attachment:2y36os4m]Little update. Car back with headcase to sort out a small oil leak. Also new fuel pump, rail and regulator has been fitted as the factory set up could not deliver enough fuel above 7500rpm. Car going for a final tune to set it up for 8500 rpm
Bought a racleogic timing device which is a great toll to measure your performance and any improvement  made to the car
Hope to collect sat
MilesH
#66
Glad to hear you're going for an uprated fuel pump. I was chatting to Patrick about the spec and we were talking about a Bosch 044 being a worthwhile upgraded, is that what you're going for?
KRAMSNEHPETS
#67
Don't know what he has fitted, Is going to fit switch to clutch pedal to set up launch control as well
ChrisGB
#68
Factory fuel pump is never going to cope with that output! I have a Walbro, I think 255lph.
KRAMSNEHPETS
#69
M25 6.20AM this morning on way to headcase for some work to be done . strange noise followed by engine missing a "beat" then cut out!. Joined AA at road side for recovery. Rotrex has lost all its oil and seized....... With Headcase now. Looks like internal failure. On holiday for a week now so going to forget about it for  a week!Hopefull sorted when I get back! Engine appears to be OK
Ouch  s:( :( s:(  wonder how that happened
Sorry to hear this.
Curious to know what has happened.
headcase
#72
looks like internal case by the impeller broken  , going back to rotrex for a warranty , no bits got to engine , charger of and already back on the way to them on Thursday . hopefully have it back shortly ,
Excellent news. Well. As good as news can get given the situation.
m1tch
#74
What rpm is the rotrex rated for? Guessing it might have gone overspeed if you are revving to 8.5k?
