2ZZ Rotrex soon!
Started by KRAMSNEHPETS, June 14, 2017, 23:26
KRAMSNEHPETS
Headcase is making great progress with my car. Fully recon 2zz in car, new rings , shelves, oil pump and gears etc. Stage 2 cams and Rotrex. Link storm ECU.Charge coole.r Car running today. got to finish off stuff before it goes to get mapped. Hardest part is that I have got  to run it in before final map...
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
Is that yours? Its going to be a beast.
KRAMSNEHPETS
It is!, My get it back end next week, then got to  run it in before final map
Blue al
Any projection on hoped for numbers
In the region of 300 bhp is what i would be looking for.
Run it in properly.
Pat will know if you dont.
KRAMSNEHPETS
Hopefully just above 300
m1tch
Quote from: "KRAMSNEHPETS"Hopefully just above 300
Is that with the stock high compression pistons?
KRAMSNEHPETS
Stock internals. Engine has been out and had a full rebuild, rings, shelves, oil pump, chain, gears, vvti unit etc. Have got to run it in
KRAMSNEHPETS
Picking up car tomorrow afternoon. Got to run it in though with the rev limit set at 4000....Got to get 1000 miles on it asap to then return for final map to release the full potential!
s12vea
Hope you have planned a road trip, let's get those miles done as quick as you can  s:) :) s:)
Another one won't hurt  .....
KRAMSNEHPETS
Going to daughters armed forces day sat, 250 round trip, 100 miles on dyno, 180 to headcase and back. 530! will try and get the rest done within 2 weeks!
KRAMSNEHPETS
1000 miles required to run new engine in done in a week.4000 rpm limit on a safe map. Car now back with headcase to sort a few things out, dashpod with display etc. Going for dyno and full map to release mall those horses. Hope to collect car sat!
jonty
Sounds great! When do we get to see pictures?
Fingers crossed for some good numbers at the end, in the USA there are a few 2zz rotrex mr2s (as I'm sure you know) and on c30-94 they seem to make about 350whp, so on UK dyno it's about that same number at the fly from most comparisons I've seen... Should be properly potent!!
keljon
did you make the supercharger brackets or buy them?
KRAMSNEHPETS
Headcase made them. He is also going to rotrex his wifes car soon as well. Car going for dyno tomorrow! Looking forward to a good new phone call or message!
Quote from: "keljon"did you make the supercharger brackets or buy them?
Headcase has a few lying around if you want one.
I think rotrex have a guide to help you make your own.
Quote from: "KRAMSNEHPETS"Headcase made them. He is also going to rotrex his wifes car soon as well. Car going for dyno tomorrow! Looking forward to a good new phone call or message!
Has it been on the dyno yet????
KRAMSNEHPETS
Car has spent pretty much all day on the dyno, results are 349bhp at the flywheel and a nice flat torque curve of 248. Am collecting it Sat!
s12vea
It's gonna be a beast!!!
KRAMSNEHPETS
you know it!
s12vea
I'm excited for you  s:) :) s:)
Quote from: "KRAMSNEHPETS"Car has spent pretty much all day on the dyno, results are 349bhp at the flywheel and a nice flat torque curve of 248. Am collecting it Sat!
Wow... That is EPIC!
keljon
Quote from: "1979scotte"
Buying a set off him to stash away for later on
ChrisGB
That's going to be a fun drive!
jonbill
That does sound like a lot of fun. Would like to see it do a 1/4 mile one day.
