V8 upgrade
Started by 8thumpers, June 18, 2017, 15:51
8thumpers
Has anyone upgraded the front brakes and if so, what did you use? I'm looking at gt4 205 calipers....
Sent from my SM-G930F using Tapatalk
MR TWO
I have thought about switching out the brakes, but the prices have always been crazy... Plus too be honest, my car stops very well on yellows & upgraded discs. I will be interested to hear from you on prices and performance if you find something and subsequently write up a report.
m1tch
Perhaps look to uprate the pads with stock discs, how much power are you running? A lighter car won't need big brakes to stop well.
8thumpers
Im looking at gt4 205 calipers and discs on the front - some modification is required and 17" rims probably for clearance.
I need big stoppers cos of the v8 going in it. The rears are audi hubs so will have A5 discs with the gt4 rear calipers.
I did wonder why the need to upgrade.
8thumpers
Would be wise I thought! The audi 4.2 is around 370bhp
wotugonado
Wilwood  do/did an upgrade for the fronts. You'll need to dig around for availability, try gt4 play in the affiliates section on here as a first step if your interested.
m1tch
Quote from: "8thumpers"I'm looking at gt4 205 calipers and discs on the front - some modification is required and 17" rims probably for clearance.
Why not go with one of the TFSi engines? More power out of a smaller more compact engine, the 4.2 V8 is getting on a bit now and its only NA whereas if you went with a 2.0 TFSi engine or perhaps the 3.0 TFSi V6 it might be a more tunable option.
JoeCool
I'd imagine it's to do with being able to get cars with the 4.2 V8 for peanuts. My mate couldn't shift his 4.2 A8 for months at a grand, and it was a good car.
Plus... V8.
2ZZ '02 Roadster
Essex2Visuvesi
Freakyparts do a kit for the fronts it's about 800 quid tho
8thumpers
Quote from: "Essex2Visuvesi"Freakyparts do a kit for the fronts it's about 800 quid though
Cheers for info. I have a bid on some calipers at mo... need a refurb but could get them for less than 100 quid... fingers crossed!
ChrisGB
Quote from: "JoeCool"Plus... V8.
This is enough of a reason on its own.
m1tch
Point taken, its a V8, will be interested to see the brake upgrade you do go for though  s:) :) s:)
8thumpers
Well I already have the v8, gearbox, audi driveshafts/hubs, Ftype exhaust and Vems ecu... be rude not to do the conversion!
Oh and nearly completed the garage too!
8thumpers
Dream workshop... only taken 35 years to achieve!!
lamcote
How does that lot fit in to an MR2? Will the engine be inline, if so will you be increasing the wheelbase?
8thumpers
The audi gearbox has it's driveshaft output between the clutch and flywheel so the distance from shaft to front of engine is only 550mm
Quote from: "lamcote"How does that lot fit in to an MR2? Will the engine be inline, if so will you be increasing the wheelbase?
lamcote
Looks very interesting, what is the solution for the rear suspension and chassis structure behind the rear bulkhead? Is the engine low enough to retain the soft top roof?
8thumpers
Quote from: "lamcote"Looks very interesting, what is the solution for the rear suspension and chassis structure behind the rear bulkhead? Is the engine low enough to retain the soft top roof?
I should be able to maintain the existing suspension turrets and am building new hub carriers to fit adjustable suspension arms to from, as near as possible, the existing chassis pickup points.
I'll fabricate a new crossmember to replace the subframe as the gearbox will go through the original. That will give oppo for extra bracing and mounts for it all too.
8thumpers
Quote from: "m1tch"
I nearly bought a v6 tfsi and it is indeed a great engine. The problem is that you can't get an aftermarket ecu to work with it because of all the interaction with the gearbox and the supercharger setup. At least you couldn't a couple of years ago... Also 4grand against 1grand for a v8
m1tch
Quote from: "m1tch"
Shame you didn't keep it Japanese and get a 1UZ-FE, the LS400s are well under a grand to buy now.
freakyparts
Heeey!! It's only £599.00  s:D :D s:D
Complete bolt on kit without any modification, and lightweight aluminium calipers unlike the ST205 boat anchors  s:) :) s:)
 m http://www.freakyparts.co.uk/epages/es1 ... k3_Wilwood m
8thumpers
That isn't bad money really. When you take into account the lack of engineering required.
Any idea on minimum wheel size?
cptspaulding
Quote from: "8thumpers"That isn't bad money really. When you take into account the lack of engineering required.
16" IIRC
Essex2Visuvesi
Quote from: "freakyparts"
Apologies.... I was looking at the rears   s:oops: :oops: s:oops:
The rears are 769 + Postage
