LSD removal
Started by keljon, June 25, 2017, 21:00
keljon
My car currently has no LSD(2zz swap) but I have the original gearbox.
I would like to pull the LSD out so I can throw the rest away (storage is tight) what do I need to keep so I can swap the LSD in later??
JoeCool
You crack open the drive side of the gearbox and pull out the diff. I think there might be some shims/bearings that you might find handy too.
2ZZ '02 Roadster
toyofan
Can you mount it that way too?
How do you measure the preload on the bearings with everything inside the box?
Mark A
Here's a guide I've followed
 m http://www.diymytoyota.com/corolla/quic ... ferential/ m
keljon
great, thanks
manos3003
Sorry I'm late to this party guys. Don't attempt this guide as it's a quick install without setting the pre-load on the differential bearings. I'll dig out the procedure I used which describes how to set the pre-load.
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
keljon
I pulled the lsd out and threw the rest away, will swap in the lsd at some point so a guide would be handy
m1tch
Quote from: "keljon"I pulled the lsd out and threw the rest away, will swap in the lsd at some point so a guide would be handy
Is it a C64 box? If so I am interested in it.
weeJohn
I have swapped a few in different Toyota boxes, never had any problems swapping the bearings over from the old diff onto the lsd. It takes a small set of pullers and you may need to grind the legs a little to get them in there, but if you take care it will be fine.
Preload is a nightmare to check without the special tool to torque the diff from the inside, like I say, 4 Toyota boxes done without checking it and no issues.
manos3003
Quote from: "weeJohn"Preload is a nightmare to check without the special tool to torque the diff from the inside, like I say, 4 Toyota boxes done without checking it and no issues.
All it takes is one time. Then it can cause some serious issues. There is a way to check without the special tool, as long as you're handy with a torque wrench
