Project Green Hornet
Started by Cabrioman, July 3, 2017, 19:02
Cabrioman
New MK3 was delivered today.   s:bounce: :bounce: s:bounce:
Had a look around and bodywork isn't too bad (apart from horrid stickers on the back) with a couple of marks. but look like they can be polished out.
Interior is good and roof needs it's ears removed   s:shock: :shock: s:shock:
First job is to see if i can get it started.
I'm unsure about the battery (300A) but going to charge it anyway. I need new battery terminals as they're missing and i have the aerial to fit.
Depending on the outcome of trying to start it depends on a full engine rebuild or just a service. What ever happens, i will be sorting out the pre-cats.
Sun Out - Roof Down
Whatever the Temperature
delhusband
Congrats, looks great  s:) :) s:)
Hate pointy animals
jonbill
Looks great. Fun ahead.
Cabrioman
Larger battery fitted,
Immob' light goes out and then turn the key
Most of the time you hear a clunk from the starter motor and that's it or on the very rare occasion it'll turn slowly.
Any Ideas?
Sun Out - Roof Down
jonbill
Seized engine? Take the plugs out, squirt some oil in and try to turn the engine over on the crank sprocket bolt with a socket and breaker bar.
jonbill
Or maybe bad earth from the battery strap?
Essex2Visuvesi
Check the alternator
Mine sat over the winter and the alternator seized making it impossible to turn over
Cabrioman
Cheers for the reply's.
I'm going to get a new battery as I don't think the one it is that good. Then I'll check the earth as it will try to turn over on the odd occasion. If not, I'll stick with the original plan and take the engine out. That way if there is an issue with the alternator etc... I'll be able to fix it while being rebuilt.
Sun Out - Roof Down
Cabrioman
Got the engine started  s:) :) s:)
Sounds like a dog though.
https://www.facebook.com/Cabrioman/videos/10213989901726729/
Seems to be squeaking from the pulleys but i'm guessing knocking is the bottom end failing?
Any other thoughts?
Sun Out - Roof Down
Cabrioman
Work has begun   s:D :D s:D
Looking a bit rusty under there   s:shock: :shock: s:shock:
But new parts have arrived   s8) 8) s8)
Sun Out - Roof Down
manos3003
Most of those rusty parts  can be replaced anyway. Or powdercoated, depending on preference.
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
Cabrioman
Quote from: "manos3003"Most of those rusty parts  can be replaced anyway. Or powdercoated, depending on preference.
Thinking of doing the arms green   s8) 8) s8)
Sun Out - Roof Down
The Arch Bishop
Love this colour and looks like it'll be a great project car. Subframe actually doesn't look too bad from the pictures which is a bonus!
Cabrioman
Engine is now complete and moved back to the garage. I've refitted the fly wheel and exhaust manifold. I've started to prepare the engine bay and I'm struggling to remove the security torque screws from the ECU so I can remove the wiring loom.
Sent from my TA-1033 using Tapatalk
Sun Out - Roof Down
These are becoming super rare now.
It's been ages since I have seen one.
Quote from: StuC on April  2, 2018, 20:15
You say that like its a bad thing  :-[
There is a room enough for everyone one, even the silvers. ;) 8)
Cabrioman
There's one up the road from me. It's perfect as I walk past it almost every day so gives me motivation to complete mine.
Sun Out - Roof Down
Cabrioman
What oil do people use?
I have the choice of 10W 40 or 5W 30.
Sun Out - Roof Down
Cabrioman
I'm also guessing I need a 1700mm drive belt with air con.
Sun Out - Roof Down
Quote from: Cabrioman on April  4, 2018, 19:48
5w 30 will see you right. :)
tomaky
Good to see your getting there bud :)
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Cabrioman
Quote from: tomaky on April  4, 2018, 21:48
Cheers :)
I'm hoping to get her started by next week but that depends on time.
Sun Out - Roof Down
Cabrioman
Engine bay stone chipped and prepped ready. Wiring loom removed and begun connecting to engine. Exhaust manifold fitted apart from 2 bolts which were too far gone.
Hoping to install this weekend and start by next weekend. :D
Sun Out - Roof Down
Cabrioman
Clutch on.
Gearbox on.
Wiring connected.
Engine mount brackets fitted.
Engine in engine bay.
:D
Going back up tomorrow to fit engine bad connect pipes.
Sun Out - Roof Down
