Removal of all exhaust heat shields - issues?
Started by m1tch, July 6, 2017, 12:24
m1tch
Hi all,
Just wondering about this, I am looking to remove all heat shield in the engine bay, will probably keep the cat/manifold to cat heat shield as I believe its welded onto the pipework but am looking to remove other heat shields such as the ones on the sub frame and in the rear bumper.
Just wondering if anyone has done this at all and if they have if they have had issues with anything melting? I know that they are there to keep hot air from the exhaust away from the air box and intake but will probably route mine behind the battery and its an enclosed cone with an inbuilt heatshield.
Just wondering if its ok to simply remove them?
alancsalt
Most of mine are gone and no issues apparent. Custom exhaust for 2zz, and CAI to left air intake behind battery.
Toyota MR2 Spyder, November 2002, Engineer approved 2001 Celica 2ZZ motor and C60 trans, MWR Carbon lined synchro set, SMT to Manual conversion, PPE headers,Fabricated Cat/Exhaust, Power FC ECU
Mrcypher
Took all mine out with no issue, as above induction behind battery out the way
m1tch
Thanks guys, so even the large heat shield inside the rear bumper can be removed without the bumper melting with a stock sized exhaust?
davew
i'm thinking of removing all of mine as well sick of them vibrating.
m1tch
Quote from: "davew"i'm thinking of removing all of mine as well sick of them vibrating.
Partly my thinking plus partly weight reduction coupled with the fact that some won't be any use anymore due to the relocation of the air intake although I believe the main one that vibrates is the welded on one on the front of the pipe that goes from the manifold to the cat.
ilovejapcrap
Are we talking the ones on the exhaust or the plates bolted on various engine / subframe ?
Or both ?
m1tch
Quote from: "ilovejapcrap"Are we talking the ones on the exhaust or the plates bolted on various engine / subframe ?
Or both ?
The plates bolted in the engine and sub frame although there isn't a heat shield on the top manifold as it's an aftermarket decat manifold.
alancsalt
Even my header heat shields are gone. Not had any problems..
