Cutting out when hot
Started by ad_car_08, July 17, 2017, 22:21
ad_car_08
Apologies if this is in the wrong place,  but wanted the advice of the mechanically minded.
My brother has an e36 328i that cuts out when it gets hot/up to temperature. Any ideas what might cause something like that to happen? Hoping it's just a sensor!?
[/size]
jonbill
Completely dies, or won't idle?
I think you can read error codes on e36 with BMW INPA.
You need a PC and a cable from  m http://www.cable-shack.co.uk m .
 m Http://www.bimmerforums.co.uk m  is a helpful forum to look on
ad_car_08
Completely dies!
Thanks jonbill
[/size]
carolineasb
And if you wait till it cools down it goes again till it gets up to temperature?
2006 (56) Blue TF300 (Newbie)<br />2001 (Y)  Silver (Oldie)
2004 (04) Black (The Inbetweenie) 2002(02) Red (Little Red Rocket)
carolineasb
carolineasb
Could it be crank position sensor?
ad_car_08
Not sure if it's the sole cause of the problem, but in taking the throttle body off to gain access to the crankshaft sensor and plug, we noticed a rubber pipe had split quite badly. Some kind of air return that went from near the MAF to the engine block?! My brother knew what it was.
Taped the pipe up with some electrical tape, just for diagnosis purposes, took it for the same drive/journey as the car took when it cut out....it was fine! Hoping a new pipe will fix the problem.
We shall see!
[/size]
stchris356
Does it take a while to start from cold, by a while I mean a few seconds rather than immediately.?
Sent from my SM-T560 using Tapatalk
Just going to spend an hour on the car !!!!!!!
ad_car_08
No, straight away, on the button!
It's only when warm he said it starts to sound a bit ropey and cut out
[/size]
jonbill
Sounds like the sort of thing a big air leak could do [emoji849]
m1tch
What are the fuel trims? Have you reset the ECU?
ad_car_08
Quote from: "m1tch"What are the fuel trims? Have you reset the ECU?
I don't know how you do those things on an e36
[/size]
