Stuck (punctured) oil filter
Started by delhusband, July 23, 2017, 14:46
delhusband
Hi, attempting my first oil & filter change. Tried removing filter by hand, but too tight. Tried using a chain type filter removal tool, but filter won't budge. I've punctured filter, so can't just top up again and put back together. Erm, please help  s:( :( s:(   bit worried about how long I can leave the engine drained of oil
jonbill
Whack a big screwdriver through it and undo it with that
Wouldn't worry about it. Just don't run it, obviously.
Stick a great big screwdriver through it and use that to unscrew it.
Or,as I do, plumber pliers. Grab that sucker, doesn't matter if it gets squashed. Coming off anyway.
delhusband
God bless you jonbill  s:D :D s:D
delhusband
(&shnazzle)  s:) :) s:)
Success!
Most cars stuff doesn't respond to a light touch  s:) :) s:)
Until you start opening up the engine or gearbox
K T M Rider
Quote from: "shnazzle"Success!
and if it's going straight in the bin after anyway - just show it who's boss   s:) :) s:)
handy things screwdrivers - I sometimes even use mine for turning screws as well
delhusband
Thanks all, feeling quite heroic now. Just finished first ever air filter replacement (blitz lm panel filter I got from E2V), first ever spark plug change and now first ever oil & oil filter change. Busy day. Back driveway looks like a massacre. Last job is to get creative with tie wraps and a Dremmel, only
3 bolts left for mid section trim, managed to shear 2 during removal.
I will never talk badly about mechanics after today,  s:) :) s:)
delhusband
Oh, and the car still starts and runs  s:D :D s:D
jonbill
Quote from: "delhusband"Oh, and the car still starts and runs  s:D :D s:D
Result!
Now you're a Pro, you can get a Bigger Hammer.
delhusband
Quote from: "Carolyn"Now you're a Pro, you can get a Bigger Hammer.
Yey! Deffo Carolyn  s:D :D s:D   Got these for now:
Oohhh fancy pants  s:) :) s:)
m1tch
I have a cheap set of oil filter sockets, seem to do the trick although they are really only meant to be screwed on hand tight.
insx
That's what I should have done yesterday rather than struggling for about an hour with a strap wrench. I seemed to recall someone saying that the screwdriver method was a really bad idea though.
This should probably  be a last resort as if you have a really tight filter you can potentially cut the filter in half with your screwdriver and then have a right mess to get off....
m1tch
Quote from: "insx"That's what I should have done yesterday rather than struggling for about an hour with a strap wrench. I seemed to recall someone saying that the screwdriver method was a really bad idea though.
Its a bit like always making sure that the fill plug is undone (on say a gearbox) before undoing the drain plug as if the fill plug is stuck then there is no way to refill a drained box - if you pierce the oil filter the car is out of action until its replaced.
