removing the rear arm adjuster bolts
Started by Essex2Visuvesi, August 6, 2017, 14:46
Essex2Visuvesi
Question time
The nut and the front plate came off without any fight whatsover, but I'm struggling to get the bolts out
Do they need knocking through or undoing?
[attachment=0:3qa87uj2] ia0 IMG_5210.jpg ia0 [/attachment:3qa87uj2]
Unfortunately, they often seize in place.  There's a massive pile of sub-frames with arms that wouldn't budge, at Rutland MR2.  Best you can do is soak for a couple of days, give the head a bit of heat, put the nut on and clout it.
We experimented, with a special frame and a 10 ton ram, on one we got from Dean.  Didn't succeed.
If you got nowhere, there is one decent sub-frame with arms at Dean's.
krazysteve
Heat, spray water on, re heat do this several times, thermal shock, helps break the rust up, and if you have a good impact gun that helps.
RACING, because football, cricket, rugby and golf only need ONE BALL
Essex2Visuvesi
The subframe is rusted anyway so it's being replaced
Not such a big problem as I have a set of Che arms to go on.  Was hoping to re-use the bolts as they weren't cheap to replace, but looking at the state of them I'll speak to TCB parts and get new ones
Rear subframe drying in the sun
[attachment=0:5tdu1c7a] ia0 IMG_5212.jpg ia0 [/attachment:5tdu1c7a]
Dinitroled the inside yesterday
Painted the outside today with a good coat of hammerite
mikek
Couldn't get mine out either. In the end I tapped them out with a hammer......Bolt and bush happily made their way out through the back of the rotton subframe!!!!
Bolts are very expensive!
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
Essex2Visuvesi
Quote from: "mikek"Couldn't get mine out either. In the end I tapped them out with a hammer......Bolt and bush happily made their way out through the back of the rotton subframe!!!!
I KNOW!
I bought all new bolts for the rest of the subframe from Paul @ TCB
I baulked at the thought of paying 12quid inc VAT EACH for some bolts at the time, now I think I'll just take the hit on the wallet and have an easy life
For Now I have injected some "Secret Sauce"* into the bolt hole and will give them a workout with the hammer tomorrow night
Sadly I don't think they will come out of my subframe as it's not rusty anywhere near them
*Secret Sauce
50/50 mix of diesel and Automatic Transmission fluid... stinky but effective
mikek
Even after I got them out of the subframe I couldn't get the bolts out of the bushes.....Good luck
JoeCool
I ended up shearing one of mine and had to replace it. Those channels just suck in water and rust the bolt in place.
2ZZ '02 Roadster
Essex2Visuvesi
Ordering some replacements, reckon it will be quicker
Also tore the captive nut out of one of the ARB brackets so the bolt just spins in the chassis rail.
Going to cut it off open up the hole fit a rivnut.... I'm at work at the moment, does anyone know the bolt size of the ARB mounting Bolts think it's M8
I just had a peek at the car on the lift.  It's got a 14 mm head, so it's probably a 10 mm, but it could be 8.... Tried a socket on it, but very tight and I didn't want to repeat your experience.
That was a big help, wasn't it??
